Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 05-20-2005, 04:23 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
93 del sol clutch problem?
well i have a 93 del sol si which we all know is Z6....well i was driving to one of my buddies house and the clutch pedal was fine then when i got ready to leave and started it up and the clutch pedal was still the same but it engaged like even if you moved it just alittle bit like half an inch...but before that it released at the top now its hard to put into gear with the clutch in.Does that mean my clutch is going out it shakes also when you down shift into 2nd gear...any help would be great thanks.
Old 05-20-2005, 06:18 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: 93 del sol clutch problem?
sounds like a master or slave cylinder problem to me...but if it was engaginging at the top before, then your clutch doesn't have much life left anyhow.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 05-21-2005, 12:48 AM
eurobeaner's Avatar
I already replaced the slave cylinder, it didnt change anything. The car has 180000 miles on it so i am thinkin the clutch is goin.
Old 05-22-2005, 07:54 PM
ImSoYesterday ImSoYesterday is offline
Send a message via ICQ to ImSoYesterday Send a message via AIM to ImSoYesterday Send a message via MSN to ImSoYesterday Send a message via Yahoo to ImSoYesterday
Re: Re: 93 del sol clutch problem?
I had the same problem, I replaced the master cylinder and all is chill, but my clutch is going as well, I am upgrading in a week, and boosting in two .
Emily's personal boyslave
TSS: Rockin' the Bitches' Faces.
B16A2 engine with:
Short ram intake.
DC Sport header: Ceramic coated, 4-2-1.
Custom headerback exhaust with disconnected muffler.
MSD Ignition system. (With Enkei wires)
http://www.cardomain.com/id/imsoyesterday
