Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 05-20-2005, 01:41 PM
natedoggaz natedoggaz is offline
Question 92 88 Royale Stalls While Driving
I have a 1992 88 Royale with the 3.8 V6 engine. It has about 104k miles on it currently. For some reason when the engine gets really warm - it will stall out on me. This can happen about 3 times while waiting for a light to turn green. The dangerous part about it is that I have to put the tranny in park before I can start it back up again...
I have read some other posts in that the issue could because of a bad CAM and or CRANK sensor? Can someone confirm this?
The bottom end of the engine was recently re-built and it has a new ignition module. A mechanic that looked at it said it could also be the "fuel pressure regulator" - could this be the cause possibly?
Thanks!
Old 05-23-2005, 10:57 AM
Installed the new CAM sensor yesterday - it was pretty easy...
hopefully this works (fingers crossed).
I should also mention that when I run the air conditioning (yes we need it here in AZ already) it it less likely to stall out on me...
Old 05-23-2005, 09:28 PM
Hansnet's Avatar
Hansnet Hansnet is offline
Re: 92 88 Royale Stalls While Driving
often or should I say most of the time the magnet breaks off and it is a PITA to fix but you could have gotten lucky with just a dead sensor.
Old 06-18-2005, 04:39 AM
joe4speed joe4speed is offline
Send a message via ICQ to joe4speed Send a message via AIM to joe4speed
I know this isn't a fix, but you should be able to just shift the car into neutral and restart it if it's moving or standing still.
Joe!
1988 Mustang GT
1993 Olds 88 LSS
http://www.joe4speed.com
Co-owner: RiceHatersClub
Old 06-21-2005, 01:46 PM
Re: Re: 92 88 Royale Stalls While Driving
The funny thing is for some reason - the car will not start in neutral. It used to, but I changed out the starter and it wont start like that anymore...
Why wont it start in neutral you think?
Old 06-21-2005, 04:53 PM
Maybe a bad neutral safety switch?
Joe!
1988 Mustang GT
1993 Olds 88 LSS
