Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 05-20-2005, 12:30 PM
Paul Flaherty Paul Flaherty is offline
Valve problem?
I just bought a 98 EB Expedition. The previous owner just had the check engine light fixed. The idle is still high and it shakes a bit. Same as before when the light was on. He said it was a valve that needed to be fixed but I see no change. There is also a noise that sounds like a jackhamer in the glove box for the first minute or so after the car starts. Anybody know if these two issues may be related and leading to a bigger problem?
Old 05-23-2005, 12:48 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Valve problem?
I would think that you have a vacuum leak.
The noise is very likely to be a leaking exhaust manifold gasket.
Old 05-25-2005, 02:03 PM
Re: Re: Valve problem?
Turns out the transmission is slipping, hopefuly it is an easy fix. The noise the is compressor for the air suspention. About $260.00 - $300.00 to replace. Dealer suggested to wait until it goes to replace.
Thanks
