Old 05-20-2005, 11:35 AM
biff_sorenson biff_sorenson is offline
Geo transmission
I have a 1990 Geo. For some reason it does not like to shift down into second or first while the car is rolling.
This problem has come up in a few Geos I have purchased and I figured the synchros were worn.
My latest one shifted fine before I put the clutch in.
Is there an adjustment I can make without removing the transmission or is it a synchro problem that can only be fixed by removal?
Any ideas would be helpful.
Thanks,
Biff
Old 05-20-2005, 02:38 PM
crazyinkc crazyinkc is offline
Re: Geo transmission
Did you replace the pilot bearing? It may be gummed up causing the inputshaft to rotate with the clutch disengaged.
Old 05-20-2005, 03:01 PM
Good idea. I too was trying to think of something along those lines.
I replaced everything. I typically get a "clutch pack". They have the throwout bearing, pressure plate, clutch and pilot bearing etc.
There is some kind of mysterious casting just below the clutch cable on the transmission. I am not sure what it does but I took it off to add my tranny fluid. Maybe I knocked something out of adjustment?
Thanks and keep thinking.
Biff
Old 05-20-2005, 09:53 PM
doug7x doug7x is offline
My '95 won't go into 1st above 5 mph...'91 did the same thing...I thought this was intentional to protect the engine, but I'm not sure about it. Never gave me a problem.
Old 05-23-2005, 08:59 PM
tyrugh5v tyrugh5v is offline
If you change the fluid, you have to use a special synthetic. that can help. My 90 Metro won't downshift into 2nd, but at any speed under 20 it will go into 1st if you goose the engine, then shift up into second. It's either that or round a corner at 15 and lug it in 3rd. Don't worry about it, just drive around it.
