Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-20-2005, 11:35 AM
[email protected] Cokevette@yaw.org is offline
electrical problem
We have a 1994 bonneville that is having an electrical problem.
There is no power and there is a ticking noise in the panel box located on the right passenger side.
The fuses are good.
Any suggestions, please
Old 05-24-2005, 04:24 PM
markwb's Avatar
markwb markwb is offline
Re: electrical problem
You could start at the beginning with the battery. Check the battery main terminals, both ends for clean tight connections. Get a voltage reading across the battery, then tell us what you have.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 05-24-2005, 09:04 PM
randman1's Avatar
randman1 randman1 is offline
I'm with Mark on this one. Sounds like a low voltage problem. The ticking, if it is a steady pace like once every second or so, is probably a relay in a module such as the RAC module. A relay, since very little current is needed to activate it, completes a circuit that drains more current that can be provided. This reduces the voltage across the relay coil and the relay turns off. After a second or so, enough voltage will be across the coil again and the whole process repeats.
