Old 05-20-2005, 09:52 AM
OJDee's Avatar
OJDee OJDee is offline
Panel lines and clear
Do you guys draw/wash your panel lines before or after clearcoating? Is there any benefit/drawback to either method or just personal preference?
Cheers
Oli
Old 05-20-2005, 10:46 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
If you do it before they will be shiny, not always a bad thing, often unnoticeable.
If you do it after, you run a chance of the clear softening the edge and filling the groove making it a little harder to get a uniform line.
So for a crisper line it is probably generally easier to do it before clear coating... - Mark
Old 05-20-2005, 11:28 AM
owlmodel's Avatar
owlmodel owlmodel is offline
Re: Panel lines and clear
i'll do it after clearcoating. reason is: i can always fix it if i done anything wrong.
Old 05-20-2005, 11:37 AM
Lambophilia's Avatar
Lambophilia Lambophilia is offline
i clear coat before i put the panel lines. i use a sharp knife to scribe the lines, then brush some thinned out paint until the panel lines are evident.
Old 05-20-2005, 11:42 AM
crisjr's Avatar
crisjr crisjr is offline
Send a message via MSN to crisjr
i always do after...
Cris
www.scaleimportracer.com
Cris Jr.
www.scalestreetracer.com
Old 05-21-2005, 03:58 AM
primera man's Avatar
"P-Man"
Clearcoat will make them shiny. You want your panel lines to look dull.
View All My Models Here.
Old 05-21-2005, 06:50 AM
OJDee's Avatar
So that's three votes for after and two for before!! Guess it's a case of suck it and see, but good to know there is no major problem either way.
Cheers
Oli
Old 05-21-2005, 04:46 PM
Amazon's Avatar
Amazon Amazon is offline
The panel line is there to replicate a void, a channel if you say. So the light that reflects back at the viewer is slightly darker, so i would suggest a darker-than-the other paint, and paint it afterwards. Satin or flat. cause when there´s little light to reflect, how could that color be shiny ? ( ..and reflect light?)
Newsflash: Diecast sales fund terror activities.
