Old 05-20-2005, 09:46 AM
BobChestnut's Avatar
BobChestnut BobChestnut is offline
Equalizer, line driver question?
I was looking on the internet at audio equipment and i ran across and equalize and line driver. I know kind of what an equalizer is but what is a line driver? Also do these items add a considerable ammount of sound quality to a system if used right?
- Chestnut
Old 05-20-2005, 12:18 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
a line driver boosts the signal in the output RCA's of the device considerably. It doesn't so much increase sound quality, but it can avoid some noise problems because the signal level is so high.
Old 05-20-2005, 06:57 PM
UndercoverPunk UndercoverPunk is offline
Send a message via AIM to UndercoverPunk
Re: Equalizer, line driver question?
DING! Correct.
Old 05-21-2005, 10:32 AM
Audio Guy
line drivers were invented because most of the head units only put out like 500 mV until like the 90's. It was causing a lot of stereos to be noisy no matter where they ran the RCA's. I have still have an old phoenix gold one, it had a receiver and tranmitter. The RCA's from the deck went into the tranmitter, it came out of the tranmitter at like 17 V RMS down a balanced line twisted pair cable to the receiver, then out of the receiver as RCA. NO WAY 17 V is gonna induce noise - even if you tie wrapped it to the power cable all the way down the side of the car.
Old 05-22-2005, 12:01 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
so basically they use linedrivers to increase the volatge to the amp through the rca's. Well can amps take that much or is there a limit to the volts they can take. Also if the line driver is hooked up to an equalizer does that mean any thing or same thing onlt with and eq there too.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 05-22-2005, 12:20 PM
Audio Guy
all audio control EQ's have line drivers built-in (that I know of) ....... it raises the signal level just before it leaves the EQ box.
