Old 05-20-2005, 09:31 AM
vifa84 vifa84 is offline
How do I remove the oil cooling lines from the radiator?
Hello,
I have a 1999 4.3L blazer and need to replace the oil coolling lines as they have a leak at one of the crimp connections. How do I remove the tubing connector at the radiator? It looks like it has some sort of retainer in it. I just want to check before I try to do it the wrong way and tear it up.
Old 05-20-2005, 10:03 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: How do I remove the oil cooling lines from the radiator?
just use a metric box wrench. 14mm I believe.
Old 05-20-2005, 11:01 AM
blazee's Avatar
blazee blazee is offline
Problem?
There is no reason to unscrew the fitting from the radiator. Just pull the little metal clip off and the line will slip right out of the fitting. The new lines should come with new clips. Install in reverse.
Old 05-20-2005, 11:40 AM
blazee's Avatar
Problem?
One more thing... in case you haven't noticed yet, removing the airbox will make swapping out the lines much easier.
Old 05-20-2005, 07:56 PM
Thanks for the info. The new line didn't come with clips, or the guy just didn't know to give them to me. I guess I'll try not the mess the old ones up.
Old 05-21-2005, 12:19 AM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Re: How do I remove the oil cooling lines from the radiator?
There called JESUS Clips cause when you break them or they fall off and you loose them you go JESUS! lol Thats what we always call them. Yeah just be careful. Wish i could tell you an easy way to get them off. there might be a tool specially designed for them, havent seen it yet thought. have fun.
Old 05-24-2005, 05:31 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
If the lines are only sweating a drop every once in a while, I wouldn't replace them yet.
Mine have been leaking for 100,000 miles now and nothing ever has happened.
People even get the link AFTER installing the new ones.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-12-2005, 06:13 PM
redwheeler's Avatar
redwheeler redwheeler is offline
a slow leak means there is a bad crimp and it could blow off at any time and by the time you realise the line blew youre engine is gone
and yes i am a ASE Master Auto Technician
1996 chevrolet silverado 5.7L 4x4
nothin but a k&n for now i just got it
Old 08-12-2005, 09:37 PM
drdd's Avatar
drdd drdd is offline
I'd second what Blazer LT says. I have original oil cooling lines at 125k. They sweat a little but no noticeable loss of oil. Make your decision by whether or not you are losing oil, not by how oily the lines look.
