Old 05-20-2005, 09:02 AM
riff22 riff22 is offline
sensor help?
does anybody know what the sensor is called that plugs into your colant? and tells the ecu if the car is cold or warm, i think it uses this for a choke. not the sensor that gives the gauge reading.
-1995 Eagle Talon TSI AWD
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-walbro 255 fuel pump
-550cc injectors
-pocketlogger
-2.5 full exhaust (no cat)
-30 psi bov
Old 05-20-2005, 09:59 AM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
Isn't it just called your coolant temp sensor? At least that's what I called it at the junkyard when I replaced mine.
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 05-20-2005, 10:43 AM
Re: sensor help?
well there is 2 sensors one of them is called that im not sure if its the one im talking about tho
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 05-20-2005, 02:00 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: sensor help?
The one for the guage is single wire connection, the one for the ECU (choke) is two wires. This is assuming 2g, I dont know off hand what the 1g setup is. The dealer or parts store poeple should be able to find it with this information.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-20-2005, 03:13 PM
Re: sensor help?
ok thanks
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
