Old 05-20-2005, 01:28 AM
plazydor plazydor is offline
Please help me
Hello!
I am from Slovenia. I have some problems witg my engine. Did anybody have servise manual for my honda. I have Honda civic 1.6i sohc engine code is D16A
Thanks
Old 05-20-2005, 01:29 AM
shaolyn shaolyn is offline
Send a message via AIM to shaolyn
Re: Please help me
what exactly is wrong with your engine?? details.
Old 05-20-2005, 01:56 AM
First, sory for my bad english.
When I was stop to drive my engine start shake and form exhaust
I see vhite smoke. I think that is somethin wrong with ingnition system.
When I will repair this, them I will start make totaly digital instrumet panel. For this I need also electric schema.
Old 05-20-2005, 02:09 AM
Re: Please help me
when you drive does it drive smooth or rough?? does it backfire a lot??
Old 05-20-2005, 02:27 AM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Headgasket maybe.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 05-20-2005, 02:31 AM
Re: Please help me
yea thats what i was thinking too the head gasket
Old 05-20-2005, 03:29 AM
When I drive, engine work OK. And tachometer some time to become mad
Old 05-23-2005, 01:24 AM
Perhaps is this stupid question (because I cant translate to my language). Where is head gasket. If you geve me desriptin, I will know what you mean.
Old 05-23-2005, 03:35 AM
Re: Please help me
between your head and your block...let me describe it in an easier way right below your headers on the head... umm above the pistons.. someone help me out here...lol
Old 05-23-2005, 03:43 AM
Ok maybe I must to set valves
Old 05-23-2005, 03:51 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: Please help me
The head gasket is the seal between the top and bottom part of your engine. Is it using any water? What color is the oil? it should be black, if it is white, then your water is in your engine oil.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 05-23-2005, 04:57 AM
Now I know what is head gasked. This part I was install new one. You aske me abaut oil. Oil is in car about 500km and is OK, there isn't water liking.
Old 05-23-2005, 05:37 AM
mmcleo11's Avatar
Re: Please help me
Pull off 1 of your spark plug wires.
Remove the spark plug and check what colour it is? Does it have oil or water on it?
If it looks funny at all, replace all the spark plugs and make sure all the wires go back on the right spark plug.
Replace your air filter & fuel filters would be a good idea if they are old.
Your fuel injectors could also be stuck open causing white smoke from over-fueling the motor, is it using more petrol than normal?
If your confused by anything, just ask. Most of the guys on here can explain.
Hope this helps...
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
