Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-19-2005, 11:12 PM
97explorersport 97explorersport is offline
AC Compressor Problem ???
My AC compressor is recycling every 2/3 seconds and makes the idle go up and down. I recently had a AC recharge could there be a leak causing the system failure?? Thanks for any info
Old 06-11-2005, 08:16 PM
fogetaboutit fogetaboutit is offline
Re: AC Compressor Problem ???
Did you figure this one out yet? My 2001 sport trac is doing the same thing. I had a code p0171 and p0174 found and fixed a vacuum leak didn't resolve the problem. I still have the p0171 code. I re-charged the air condition. That didn't work. It may not be the air compressor. Turning on the air conditioner puts a load on the engine and may be making the real problem more noticable but heck if I can find the problem. Looked at and checked the MAF. Looked at all the vacuum lines I can find. Changed the PCV. I hear horror stories about taking this to the dealer with a p0171 code. The dealer likes to just change parts until they find if they find what the problem was.
Old 06-11-2005, 10:59 PM
Re: Re: AC Compressor Problem ???
High Pressure switch was bad. Replaced the switch and all is well once again
Old 02-17-2007, 04:10 PM
bacchus_00 bacchus_00 is offline
hi, i have a 98 explorer sport when is cold the a/c works but the compresor clutch works for about 10 secons and then stop to work for another 10 seconds and so on , ...... i change the swith located at the top of accumulator .and the problem still there... is that switch the high pressure switch?
Thanx
german
Old 02-17-2007, 06:45 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Have you had the pressures checked in your A/C system to make sure they are where they should be? You could be low on R-134a or overcharged. Start with the basics before replacing parts.
-Rod
