My Safari Wagon which has138,000 on it and has been very dependable car has developed a start a die problem. It has a two month old fuel pump and good fuel press.but it seems to loose ignition spark when i let go of key after cranking.No codes on computer switched ecm no help,replaced ignition module it ran for 10 mins and went back to same problem. I have checked for correct volteges bad grounds broken or loose connections cant find any. This wagon has distributerless ignition I'am thinking crank sencer now Any Sugestions would be helpfull. Thanks Scout943
Re: 1990 Safari Wagon Starts & Dies!
The crank sensor would be a good place to look especially since it starts and dies. The other place to check is the ignition switch itself. Sometimes these go bad and will cause similar symptoms.
