Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 05-19-2005, 06:27 PM
2000hondacivic4dr 2000hondacivic4dr is offline
Send a message via AIM to 2000hondacivic4dr
radio code
i recently had a new battery put in and i need a code. does anyone one for 2000 honda civic dx. i dont know if there is a universal one or just models or vin numbers. any help would be greatly appreciated
Old 05-19-2005, 11:34 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: radio code
take it to honda.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 05-19-2005, 11:44 PM
alfonso2501 alfonso2501 is offline
Send a message via AIM to alfonso2501
There should be a sticky about radio codes. Anyway, when you do take it to Honda don’t let them talk you into charging you an hrs labor to take it out of the dash and reset the radio! It’s a way they rip off customers! There is a code in the glove box, or under the armrest; they run that number thru the computer which spits out the radio code. The trick is you have to subtract the last digit that the computer gives you. You also have to try to find someone who will take the time out to do it for you @ the dealer ship which is like pulling teeth.
Old 05-20-2005, 12:29 PM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
Re: radio code
pull the radio out, write down the serial # and go to the dealership with the car. $5 gets you the code. when i went i was purchasing like $100 worth of engine parts so he gave me the code for free
Old 05-21-2005, 01:47 PM
AF - Advisor
Re: radio code
my local honda does it for free.
Old 06-02-2005, 01:21 PM
titantn24 titantn24 is offline
I ran into this same situation after disconnecting the battery while installing an AEM cold air intake. Instead of paying the dealership or someone else for the code, I opted to purchase a new deck instead. The factory one was ugly anyway. However, there is a site that I used to find removal instructions for the factory unit. You'd be suprised at what all you have to remove just to get the deck out. The site is www.hondaunlockcodes.homestead.com I paid like $3.99 for the removal instructions. I think they charge around $25 to generate a code, but you'll still have to remove the unit first to get the serial numbers and stuff. Unless you really like the factory deck for some reason, I would just replace it with an aftermarket one since you have to go to all the trouble to remove it anyway. Just thought I'd put my two cents in.
