Old 05-19-2005, 01:59 PM
herkyhawki herkyhawki is offline
Question Electrocharger
I don't know what to think of this.. but it could be possible.
http://www.sigmaautomotive.com/elect...trocharger.php
It installs in place of your alternator and operates as an alternator most of the time. But, during hard acceleration it runs as an electric motor to ADD torque to the crankshaft (via the belt) instead of being a load like a regular alternator.
The website also claims that by using this your vehicle meets the definition of being a HYBRID, so you can qualify for Hybrid TAX Credits.
What do you think?
Old 05-19-2005, 09:52 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Definitely interesting. Possibly a scam, but who knows?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 05-19-2005, 11:17 PM
MRogers's Avatar
MRogers MRogers is offline
Re: Electrocharger
If it works the way they say it does, it would change the gas mileage in the city to about what it would be on the highway, but I doubt their electronics are that good as it is a universal type kit.
'89 S10 Blazer 4.3 V6 4X4 with LOTS of rust.
Old 05-19-2005, 11:53 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Electrocharger
With the high electric load, the gain would be offset by the load of the high output alternator.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-20-2005, 07:24 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Electrocharger
If you look at it from a purely electrical or energy stand point it is obvious that it can't operate as well as described. Basically it takes energy to create energy and even with all the advancements that have been made in the energy field it is still impossible to get more energy out of something than you put in.
Fuel is burned turning the engine, (energy is lost, wasted as heat energy) The engine turns the Electrocharger, (more energy is lost, resistance of the bearings, inertia, rolling load, etc...) The Electrocharger converts the movement to electricity (more energy is lost, the resistance of the wiring in the coils, energy used to generate the magnetic field, etc...) The electricity is stored in the battery (more energy is lost, no battery is 100% efficient) The electricity is used to turn the Electrocharger (more energy is lost, creation of the magnetic field, resistance of the coils, resistance of the bearings, inertia, etc...) The Electrocharger turns the engine using the remaining energy that wasn't used up as it changed forms.
There is absolutely no way that using the Electrocharger can be more efficient (engine efficiency is measured as MPG) than just using the gas to power the engine. At certain times the instant MPG may be more due to the release of the stored energy, but over all the average mpg will be lower due to all the energy that was lost storing the energy in the first place.
Old 05-20-2005, 07:52 PM
blazee's Avatar
Problem?
Re: Electrocharger
Wow, I said energy 16 times in that post.
Old 05-20-2005, 08:54 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
Re: Electrocharger
and of course i went back and counted them too.. lot of energy
Old 05-21-2005, 12:14 AM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Re: Electrocharger
I agree with blazee on that one. but through the use of pullys or gears it is possible. Who knows though.
Old 05-23-2005, 12:39 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Electrocharger
^^no, its not, power out, is NEVER higher then power in, that would be perpetual, and instead of developing a better alternator with perpetual motion, i would... i dont know... make a power plant and make billions selling the free energy i create... and cause billions in damage throwing the physics community into a loop
Old 05-23-2005, 08:16 AM
Re: Electrocharger
It mentions "regenerative braking" a couple times. This is how it would gain power that it otherwise lost in braking. You would need some type of coils/magnets assembly connected to driveshaft or in wheel hubs to accomplish this. It would have to be incredibly expensive to retro-fit. When Gas hits $5/gallon I'll take another look.
Old 05-23-2005, 10:15 AM
Allbert Allbert is offline
Re: Electrocharger
The regenerative braking would work best in a manual transmission if you didn't use your brakes and downshifted to let your engine spin the electrocharger, but even in an automatic, the engine braking effect is fairly signficant (even more so if you manually downshift the automatic while slowing), so the idea of recouping the energy that is otherwise lost to heat in your brakes makes sense.
Old 05-23-2005, 11:04 AM
Re: Electrocharger
you go right a head and constently downshift to slow yourselfe, not being cocky, but that will start to take a toll on the transmission, manual or automatic
Old 05-23-2005, 01:09 PM
Tangent Tangent is offline
Re: Electrocharger
I'll keep my opinion short:
This is just a more complicated version of The Tornado, fuel magentizers, or any number of other intake boosters... Big promises, a bit of name dropping, some hints, but in the end it's junk.
Old 05-24-2005, 08:30 AM
No argument there... brakes are a LOT cheaper than clutches. Also, I'm not suggesting that the electrocharger is necessarily a practical modification for any vehicle, but I could see it maybe being worthwhile on a small engined manual transmission car... even more so if it actually has enough torque to start the engine and vehicle from an engine-off dead stop like some other electric hybrids (like golf-carts) do. If you can get 4 or 5 horses from an electric motor/generator, that's a big boost for something like a Fiesta or a Metro... not so much for a 190 HP Blazer.
Old 05-24-2005, 10:05 AM
crazycory1 crazycory1 is offline
I don't think thier talking power in / power out with this type of charger. It works like alternator by charging your car battery and the chargers battery (only at high speed) that you put in the trunk, then when the charger reaches a certain speed (idle to certain speed), it turns into a motor and trys to spin faster than the crank taking some load off the crank. Will it work, maybe but more than likely not. There is always loss. The voltage drop from the wiring that runs to the trunk must have a huge drop when the charger turns into a motor. Think of the amount of current it must take to turn the charger fast than the crank. I might kill both batterys if you get stuck in traffic.
I Don't think it will work. It is working backwards in design of the new hybrid cars. The new hybrid cars use the gas engine up to a certain speed then switch to the electric motor when on the load on the engine is min. and the gas motor switchs from driving the car to charging the batterys.
More than likly a scam. Why are they waiting to post the data results till the end of the summer? If they are making claims about how well it works they would have the data already. They are just trying to suck people out of thier money before they disappear and are never heard from again.
