Old 05-19-2005, 10:31 AM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Engine Inefficiency
After I hit 3800rpms the engine bogs a bit and feels like its really struggling all the way to redline. Its fine up till 3800, what could cause this quirk? I dont think its a stuck belt or tensioner because this happens only above a certain rpm in ALL gears and not before. Could it be that the system can't get ou the exhaust fast enough, injectors arn't fireing, spark plugs dying ? whats do you guys think?
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 05-19-2005, 01:44 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: Engine Inefficiency
I would check for a lack of fuel or a clogged exhaust system. Those are the only things that really make sense in your case.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 05-19-2005, 03:51 PM
Does it on full tank. What/how would I look for stuff in clogged exhaust?
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 05-19-2005, 04:44 PM
Dober89 Dober89 is offline
how about a fuel filter maybe?
Old 05-19-2005, 04:52 PM
i dunno, would that make that kinda problem?
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 05-20-2005, 11:15 AM
If the problem is that the engine isn't getting enough fuel it could either be a pump that's going, a clogged fuel filter, or some kind o regulator that's screwed up, I don't know what kind of regulators they have. If it's your exhaust you can try somehow unhooking it before the cat, that way the exhaust can escape freely and you'll know that's what it is. It is gonna be loud as hell though so I wouldn't recommend that unless you can get out into the country some place where nobody will bitch about it.
Does it do this if you just rev it up? or is it only when it's in gear?
2006 Hyundai Sonata
Old 05-22-2005, 08:36 PM
Only if I'm in gear.
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 05-23-2005, 03:46 AM
If it only does it when you're in gear I would say it's something else, I don't know what else it could be but if it revs nice but just runs shitty when it's in gear I would guess it's something in the drivetrain.
2006 Hyundai Sonata
Old 05-23-2005, 10:37 AM
gotcha, the tranny is acting up, it 'pops' when i shift too hard/quick and the synchro's suck for 1st and reverse. I have to force it in and rub against something that feels like a fan sometimes to get it in gear.
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 05-23-2005, 04:21 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
sounds like two problems....
Tranny - seems like your syncro's are bad
Engine - put a new fuel filter on and the problem will probly go away
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-23-2005, 10:08 PM
96Civ's Avatar
96Civ 96Civ is offline
Check your spark plug wires. Take each one off one at a time and look at them. Sometimes wires get loose and that will make your engine bog at mid-high RPM.
Old 05-23-2005, 10:41 PM
Changed fuel filter *smells like gas still* and it seemed to gained like 30hp no kidding, but still bogs on occasion, will check spark plug wires next. What else could it be to make it bog?
And while lifting up rear end the back tires DO NOT ROLL. The e-brakes (drums) are locked, how do I fix that?
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 05-24-2005, 10:19 AM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
is it in neutral and is the parking brake off?
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 05-24-2005, 10:32 AM
Neutral AND parking brake is off.
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 05-25-2005, 04:41 PM
89IROC&RS's Avatar
now that youve put the fuel filter on, run it for codes again
