Old 05-19-2005, 10:29 AM
iwilkerson iwilkerson is offline
Lack of Power
Well I fix one problem and another pops up, so here we go. 87 5.0 now has little or no power, it happened before but the graphite post was messed up, I replaced the Dist Cap and rotor and fixed it for about a week and now the same symptoms are back, when you rev it up it has a funny sound almost like it is not getting enought spark and it will start to flood down and stall at idle. Help again!
thanks
Ira
Old 05-20-2005, 08:58 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Lack of Power
did you check the coil out?
Old 05-20-2005, 11:22 AM
Re: Lack of Power
thanks
Ira
I am not sure what coil out is but the wires are connected, could the coil be going bad and can this be checked?
thanks
Ira
Old 05-20-2005, 11:33 AM
wrightz28's Avatar
Re: Re: Lack of Power
thanks
Ira
that's what I menat, have you tested the coil, yes it can be done, you'll need an ohmeter. if not available or you're not sure how, a reputable parts store could help you out. but it is rather easy to do on your own.
Old 05-25-2005, 08:53 AM
jaime_cartero jaime_cartero is offline
Re: Lack of Power
Is your timing outta wack? You could loose alot of power if your timing is retarded.
Old 05-25-2005, 08:56 AM
wrightz28's Avatar
Re: Lack of Power
I think that was covered that in a previous thread?
Old 05-25-2005, 09:28 AM
I know and thats the thing I havent checked yet, but would the power come and go? Also it is burning the inside of the New Dist Cap and Rotor contact points, I just put on about a week ago,along with Wires and plugs.
thanks
Old 05-25-2005, 09:47 AM
Re: Lack of Power
Could also be bad coil, or a bad wire giving you that burning. Check all the wires, especially the coil wire to see if its old, and or has corrosion in the boots.
Old 05-25-2005, 11:05 AM
wrightz28's Avatar
what he said
Old 05-25-2005, 12:17 PM
Re: Re: Re: Lack of Power
what he said
I might just replace the coil. Anyone of you have a good coil, I dont need High performance just something decent and a little hotter than stock?
thanks
Old 05-25-2005, 01:56 PM
NoRiceHere01 NoRiceHere01 is offline
Re: Lack of Power
check the ditributor to make sure its tight.if its not then it will turn when the engine revs.if the timing isnt right then engine temp will make a difference in power.ive found that detonation is more likely once the engine warms up.id replace the cap again but with one from Accel.theyre about $25 and theyre as good as any other brands.the accel coil is probly $50 or $60 but its worth buying and is great for stock or performance engines.checkin to make sure its the coil first would be the smart move tho.
