Wont idle
Having trouble with my 1996 Geo Tracker. Starts and runs fine. Problem is when I come to a stop the idle dips down and car dies. Starts right up and idles fine after restart. But problem happens again when I go to stop. Ideas anyone? Does this with or without AC on. It is a 4x4 also. But never use it.
my 96 is doing the same thing. but when you turn on a/c it idles fine.
i am going to change idle air control valve. will let you know the outcome. i will fix it. steve p. s. mine has 49,000 mi how many is on yours |
Re: Wont idle
Thanks for the reply, and please let me know how it came out and how much you paid for yours, Autozone and Oreillys did not have a part number for mine. Mike |
Re: Re: Wont idle
Mine was doing the same thing. I took the IAC Valve off and cleaned it several times with some starting fluid and then blew it out with an air hose. It had some carbon build up in it. When I blew it out with the air hose some of the carbon particles came out.It's been 2 weeks now and still idiling fine. Hope this helps.
Re: Re: Re: Wont idle
Will try that today, thank you for the suggestion.
Re: Re: Re: Re: Wont idle
Where is it located on the engine? Is it complicated to take off?
Re: Wont idle
Anyone out there have a (solid) solution for this one? It would be much appreciated.
Thanks, DG |
Re: Wont idle
Does your engine stall when you remove you foot from the Accelerator pedal rapidly? If so try the electric dash pot. It looks like the idle stop on the throddle body. Engines must slow down slowly. Good luck. |
Re: Re: Wont idle
Re: Wont idle
mine dies down only because my #1 cylinder dont work...but it dont die completely it just skips hardcore.
When you let off the accelerator pedal fast a car engine will always stall so about 40 year ago they started using mechanical (spring) device to slow down the rate of closure of the butterfly in the carb. In late model cars they use electric and vacuum to control this device It was called a dashpot. On your tracker you will find it as an idle stop located where the throttle cable ends on the quadrant ( the thing that rotates the butterfly in the throttle body) When you move the Quadrant to increase RPM's the little piston moves out and when you close the Butterfly the piston contacts the Quadrant. If you increase you idle RPM's and your engine doesn’t stall (try 1000RPM) This may be your problem. Good luck |
Thanks again, Dave |
Re: Wont idle
did you check your egr valve
Re: Wont idle
Check for leaking or cracked vacuum lines as well. Make sure that the little plastic tees and Y's where the vacuum lines connect are solid and haven't cracked. Good thing its a small engine, there aren't as many to chase.
