Old 05-19-2005, 01:30 AM
jdmstreethatch jdmstreethatch is offline
What primer for gloss red??
I used gray primer on my model and sprayed gloss red over it and it looks more like orange. Should I used white primer instead for red??
also, whenever i spray paint gloss black its always too thick and looks terrible, any tips??
thanks
chris
J-Spec EK
Old 05-19-2005, 01:44 AM
cfcrules's Avatar
cfcrules cfcrules is offline
Hi, if your in the UK, the best thing for red primer is the halford plastic red. Its a very dark burgendy red, that when sprayed over with gloss becomes a nice bright colour
Old 05-19-2005, 04:24 AM
mozli's Avatar
mozli mozli is offline
Re: What primer for gloss red??
i'd go with either Halford's red primer or Finisher's pink primer! both works great!
Old 05-19-2005, 05:02 AM
RallyRaider's Avatar
Zomby Woof
Yes if you're after a really bright red, then white undercoat would be the way to go, depends what look you are after. As mentioned above pink is a common undercoat when using red, especially if you are after a more scarlett hue. Some of the really bright reds do cross over to the orange side so possibly that is the way the paint you used is ment to look?
If your black lays down too thick then thinning it would be the obvious answer, or are you doing that already? Remember it is better to paint several thin coats rather than a single thick one.
Old 05-19-2005, 07:48 AM
proosen's Avatar
proosen proosen is offline
I've used orange as a base coat when I painted with Humbrol's red #19 and it gives a very bright red. Otherwise white is a good choice.
Niclas
Old 05-19-2005, 07:53 AM
Vric's Avatar
Vric Vric is offline
thanks
chris
First question, what kind of paint do you use ?
As for primer, when painting White, yellow, red or anykind of light color, you need White primer.
Old 05-20-2005, 03:06 AM
primera man's Avatar
"P-Man"
White primer for light colours
Grey for darker
How to prepare and paint bodies
View All My Models Here.
