Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-19-2005, 01:07 AM
matth matth is offline
Unhappy wont start HELP ME
Ok need a little bit of help?
I just got done doing a 1.8 to a 2.0 put in a jdm 4g63 new wiring harnes ecm from a junk yard and all the great stuff that goes with this pain in the a$$ job. got her running for about 3 days intill I did the smartise thing and did a nice little burn out. the car did nice smoked in 1st and 2nd but when I went into 3rd heard a nice grinding sound and lost all my power. Then the car would only crank now its been about a mth since this has happend the engine will turn but will not start tryed replacing crank angle sensor, ignation power trasister coal pack ecm still wont start has gas going to the engine pluse fire checked all the fuse none bad any idea.
Thing that really sucks is my wife says that I have put to much money into this car and she will not let me put any more into it. So if I could just figure out if I blew it or if I just killed a sensor it would help if not I have a 93 eclipes with a jdm 6 bolt engine a exedy clutch and a bunch of nice goodies. Like a act lite wight flywheel for a turbo that I got to get rid of case my landlord is geting mad about the car just sitting around so if I cant find the problem in a mth it will go to a junk yard. Are one of you guys just got you a fixer up for $800 let me know some way to fix this are just take it off my hands im in greeneville tn HELLLLLLLLPPPPPPPPP MMMMMMMMMEEEEEEEEE
Old 05-19-2005, 03:08 AM
dean,can dean,can is offline
check timing belt.
Old 05-19-2005, 03:44 AM
Re: wont start HELP ME
the timing belt is still thier when I go to crank it it turns what should I be looking for?
Old 05-19-2005, 03:48 AM
When the problem happen I just drove to my bro house and was on my way to work drove it for about 50 min then it lost power the engine felt reeaallyy hot do you think I could of killed the temp sensor might be a stuped question but shit with do I have to lose.
Old 05-19-2005, 08:22 AM
RSLaser RSLaser is offline
CHeck your timing, make sure it lines up with the marks...was it makin any noise befor it happened?
1991 Plymouth Laser RS
Only sat for a few years....
Old 05-19-2005, 07:15 PM
yes only when you start the car up it grind a little but I thought it was the starter the car did idle a little funny when it first start but thought it was just the cable needed to be adjusted could anyone tell me how to line up the timing lines are what to look for when doing it case I can pull a engine but the timming is a new world for me
Old 05-20-2005, 08:22 AM
When its actually running do you hear any noise coming from the the head? Sounds like my sonett, you may have broke the rods. That may be the grinding noise you hear too.
Old 05-20-2005, 08:19 PM
o while if its a broken rod thier is no reason in trying to fix it. but Iwill still try to get the timming stright and see if it is a rod thanks rslaser for all the advice
