Old 05-18-2005, 11:59 PM
bnrboy775 bnrboy775 is offline
Send a message via AIM to bnrboy775 Send a message via MSN to bnrboy775 Send a message via Yahoo to bnrboy775
whiney tranny
my transmission, is making a whineing noise, i just had the clutch and all that junk replaced...still doing it though, my mechanic said that i was low on tranny fluid and thinks that may have caused the whine noise, anyone have any thought....it is a 98 s-10 5 speed
Old 05-19-2005, 01:59 AM
whitetrash982 whitetrash982 is offline
Send a message via AIM to whitetrash982
trans
in every gear? cuz i know on just about all the newer ones ive driven , they all whine a bit , specially in 1st gear , infact alot of trans's whine in theier lower gears , if it still whines in 4th gear tho , that could be something gone bad , like a bearing maybe , other then that tho , sometimes theyll gradually whine louder and louder as the get older , but itll only get so loud
Old 05-19-2005, 09:57 AM
OverBoardProject OverBoardProject is offline
Banned
Re: whiney tranny
Check the oil.
There is a good chance that they drained it to replace the clutch, and just filled it with regular 80-90 oil.
I believe that it should take ATF fluid, but check your owners manual first.
ATF fluid is usually thin and red.
And 80-90 is dark, thick and stinks
Check it yourself, it isn't that hard and then you'll know who's responsible if there's any damage.
If it happened it's a simple honest mistake, so don't be mad at them.
Old 05-21-2005, 01:06 PM
Re: whiney tranny
they checked the tranny fluid and added Sycromexh, which is what the book said to add and oriellys said to add, he said that it looked like it had been leaking for a while, as for the whineing noise we thought it was the pilot bearing that was going out, and its been doing it for a couple months now, and i figured that it would stop when i got all the clutch assembly replaced and it didnt, any ideas?
