Old 05-18-2005, 09:11 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
lifting or lowering a truck?
i have a 2002 silvy and it is a 2wd. but i want it to sit level like a 4wd. what can i do? i would rather lift the front. i have 3 1/2 inches in the front and 5 1/2 inches in the rear for a gap between tires and fenders. what is the best way to do this and how much will it cost? up 2 in the front or down 2 in the back?
Old 05-18-2005, 09:41 PM
3wbdriver 3wbdriver is offline
The less expensive route would be a 2" drop at the back. This would simply require putting in a longer aftermarket spring shackle on each side. Most quality lift/lowering kits for the front end involve rather expensive front spindles, and paying someone to install them. You might get by with a set of spring spacers on the front, but I don't think you'd care for the look with the A arms stretched down 2 more inches. If you don't carry a heavy load very often, I'd go with the rear drop.
GAS IT TIL YOU SEE GOD, THEN TURN LEFT!!!!!!
Old 05-19-2005, 12:02 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Yea, a 2" drop shackle in the rear is the quickest and cheapest to do. To do the front I would recommend doing spindles, but thats just me. a set of 2" lift springs can be had pretty cheaply.
*Under Construction - New sig to debut*
Old 05-19-2005, 12:07 AM
this is what is looks like. its no bad but u can tell the back is higher.
Old 05-19-2005, 12:15 AM
where can you get a 2 inch drop shackle that will bolt on easily? how much should i expect to pay? thanks
Old 05-19-2005, 06:41 PM
Ask and ye shall receive. There is a phone number and a link at this site. Couldn't find a price, but it'll get you started. I think with the 22's you'll look better dropped than lifted. But I do miss the Black Maxx's.
http://chevytruckworld.tenmagazines....720-lpid-18658
Old 05-19-2005, 09:15 PM
i think u got my truck and another mixed up. i never had the black maxx's. those are on another guys truck and its a stepside. but thanks for the link. i will check for prices.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 05-19-2005, 09:47 PM
Re: lifting or lowering a truck?
You're right. That was Jethro's truck. OOPS.......
Old 05-19-2005, 09:57 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Here's some:
http://www.joegibbsperformance.com/p...e.php?perNum=3
~$80, not too bad. Would doing a 2" drop in the rear make a noticeable difference in how the truck handles?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 05-19-2005, 10:06 PM
I wouldn't think it would affect handling, except possibly to make it a little better through the curves, due to a lower center of gravity. The biggest thing I think you would notice is the loss of up travel on the springs, because you have moved them that much closer to the bump stops. If you don't drive on very rough roads, you'll probably not notice any difference at all.
Old 05-19-2005, 10:39 PM
it should not effect the ride to much. it may make it ride ruffer i would guess but i am not to worried about it. i am gonna get a set and i will try to remember to post how it worked out. and how the ride is.
Old 05-20-2005, 12:11 AM
It'll ride fine. Nothing to worry about. Definately lower the rear it will look far better with the wheels and tire combo.
Old 07-28-2005, 11:21 PM
John's 02 John's 02 is offline
Send a message via AIM to John's 02 Send a message via Yahoo to John's 02
Thumbs up Lookin Good!!
I also have a 02 Silvy that im wanting to drop a few inches 2 front and 4 rear and put some rims on....the rims on your truck are 22's? Do they fill the fender well better than a set of 20's? Let me know thanks!
Old 07-29-2005, 09:23 PM
ya they are 22's, but i had to get a heat gun and get the inner fender liners pushed back a 1inch or so to keep them from rubbing . and if i hit really big bumps now and then i can get the front tires to hit the underside of the fender, but lower pro tires would be better. i haave 305 45 i think. i did a 2 inch rear drop and thats it and they fit well.
Old 07-29-2005, 11:53 PM
spudglo08 spudglo08 is offline
Send a message via AIM to spudglo08
Put some ford keys up front on it.
