Old 05-18-2005, 09:07 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
Unhappy any one take a mirror apart?? i need help!
i am going to take the mirrors apart and i dont know how to get the glass out of them? does any one know how. i got the mirror off the truck and i got the chrome covers off, they just had double side tape and like 4 clips that held them off. but i am not having any luck and taking the glass out or taking the housing apart. help would be great thanks guys
Old 05-18-2005, 11:46 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Re: any one take a mirror apart?? i need help!
Very carefully, VERY CAREFULLY.... tip the glass and get a pry bar under so the tip of the pry bar goes close to the center and push up. I've wondered if you can reach the locking tabs at the circle and pull a few loose and then pull the glass off. Good luck, I've got three off successfully and two broken. Not great odds for me.
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 05-19-2005, 12:03 AM
i got it apart. its actually not that bad. i tipped the glass and then i got a long skinny screw driver and i popped like 4 clips loose and then is just unsnapped around slowly and came off and the the rest of the mirror came apart with clips and a few screws here and there.
Old 05-19-2005, 10:45 PM
i am painting my mirrors once i get them done i will post some pics. then once the mirrors are done its the tailgate handle then the drill and ................. it never ends hahaha
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 05-20-2005, 07:12 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
While u got your mirrors off, you ought to upgrade to those with the turn signals in them.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 05-20-2005, 10:53 AM
what do i have to do to add the turn signal mirrors? i will do it if it isn;t alot more work. i already have one mirror sanded down and getting ready to paint. do i just need new glass and then run wires or what? thanks
Old 05-20-2005, 11:00 AM
I'm not sure exactly
Old 05-20-2005, 02:14 PM
jethro_3's Avatar
One wire to ground on the door, one wire to the cluster under the dash per door. Simple, well worth the time. Found mine on eBay, came with directions.
Old 05-20-2005, 07:43 PM
what kind did you get and how much are they?
Old 05-21-2005, 12:38 AM
jethro_3's Avatar
Make sure they are the Muth, they are direct replacements for the '03 and up models like Tahoes, Yukons and other GM lines. They are quality mirrors. I got mine off eBay delivered for something like $175, can't remember, with the extra wires and directions included.
