Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-18-2005, 04:38 PM
saprano3 saprano3 is offline
Send a message via Yahoo to saprano3
Question wiper problem
I have a 1995 chevy suburban LS and sometimes the wipers will work ad sometimes they won't, they will quit without returning to the bottom of the windshield sometimes I've replaced the turn signal/cruise control/dimmer switch/wiper controls no help. I fiqure it's has to be the wiper motor, anyone seen this sort of problem before?
Old 05-19-2005, 12:59 PM
gregory914 gregory914 is offline
Re: wiper problem
Look back a few months in this Forum, this is a common problem and GM had a recall but the fix is easy, read the threads about wiper problems and you'll see. All you do is take out the circuit board from the wiper motor (on firewall driver side) and put a new one in or repair it by re-soldering the connections where it plugs in, be careful not to crack the board and I also cleaned off the contacts that rotate around with the motor. Good Luck!
Old 05-19-2005, 10:08 PM
Franko914's Avatar
Franko914 Franko914 is offline
Re: wiper problem
Check the following from the Tahoe section:
http://www.automotiveforums.com/vbul...d.php?t=380312
US Supreme Court Upholds the First Gun Law: The Second Amendment
Old 05-20-2005, 08:53 PM
Re: Re: wiper problem
thanks greg I will try that
Old 05-20-2005, 09:07 PM
thanks frank got some great info
Old 05-23-2005, 09:00 PM
Franko914's Avatar
Re: Re: Re: wiper problem
You're welcome! Somehow, it was easier to resolder the 98 Tahoe's than the 86 Sub's. Instead of making it easier to repair, you'd think they'd just fix the bloody problem.
