Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-18-2005, 04:12 PM
markwedge markwedge is offline
Question how do I remove front speakers on a 93 lude. please help
please help my front speakers have blown and im not sure wether to remove the whole door panels or just the grill im not that technical and need some of your help thankyou mark
Old 05-18-2005, 04:47 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: how do I remove front speakers on a 93 lude. please help
Use the search function. It's been covered before, I'm not sure if it was in this forum, or the Interior/Audio/Security, but they explained how to do it. I know you have to take off the door panels though.
Old 05-18-2005, 09:07 PM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
take off the panel on the door that has the power window switch, door handle and lock, the screw is behind the door handle. When this pulls off unplug the wire connector to it. Next take off the plastic corner piece up top near the window, it pops off with a screwdriver I believe. There should be a screw behind it. Next unscrew about 5 screws around the perimeter of the panel. ONce this is down push the door panel up and out. It has to be pulled up to get out of the window piece. It then pops off. You'll then see the speaker. Some speakers are deep and you will need modification to have it fit in. It depends on the speaker, i Have Boston Acousitc FX-6H's i believe, something like that. The H stands for honda, as it is narrow and fits perfectly.
good luck
