Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-18-2005, 01:35 PM
snipez's Avatar
snipez snipez is offline
2005 honda civic windshield problem
hi
brand new car.
there are small dots everywhere on the back window.
could this be caused by parking under a tree>>??
because the day after i parked under the tree i was going to work and was getting smear marks on the front, and lots of dots on the back.
water runs away from the spots.....
when mositure is applied to the window the dots faintly appear, but you see nothing when dry.
will stripping the window help, or is that not reccomended on a new car???
Old 05-18-2005, 02:07 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: 2005 honda civic windshield problem
just get some bug and tar remover and wipe it down.
Old 05-26-2005, 03:01 AM
snipez's Avatar
Re: Re: 2005 honda civic windshield problem
tried that.. no luck
it seems the oil or whatever it is, is in the glass itself, if that makes any sense.
and at certin angles it appears that there are thousands of small dots, look like sun spots or something, but they are hard to see. this again with absolutley nothing on the window
what do i do?
is it defective glass, or am i screwed?
the only time you see the dots is when water is applilied.
Old 05-26-2005, 05:51 AM
Copytech99 Copytech99 is offline
It could be the process used for the polarization, Most newer cars you can see almost white "spots" in the glass. (at least I can) They also appear in the other glass as well. If you own polarized sunglasses try looking at the spots with and without them to see if they change/disappear.
Old 05-26-2005, 07:15 AM
snipez's Avatar
what kind of alcohol can i use? i heard rubbing alcohol works on tree sap?
Old 05-26-2005, 06:48 PM
Most OTC is like 70%. You could try some in a small area as a test.
