Old 05-18-2005, 11:00 AM
Jergin01's Avatar
Jergin01 Jergin01 is offline
Whats the lowest you can go?
What is the lowest drop you can do on a 2000 Blazer with 20 inch rims (255/40/20)?
2000 S-10 Blazer LT 4.3L EFI 4DR 4WD
Alpine CDA-9835 Headunit w/ iPod
Custom Wheels w/ Toyo 255/40/20
Custom Exhaust - 3" Chrome Outlet
All Clear Lights w/ L.E.D Bulbs
Silver Interior w/ Brushed Aluminum Trim Pieces
Check out my Blazer on CarDomain.com
http://www.cardomain.com/ride/856449
Old 05-18-2005, 12:00 PM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
Re: Whats the lowest you can go?
4WD or 2WD?
4-Door or 2-Door ?
1999 Blazer LS 4WD 4.3L "W"
2004 Silverado 2500HD Duramax
Old 05-19-2005, 11:31 AM
Jergin01's Avatar
Re: Re: Whats the lowest you can go?
Originally Posted by TonyMazz
4WD or 2WD?
4-Door or 2-Door ?
4WD 4Door
Old 05-20-2005, 08:44 AM
MethodMan420's Avatar
MethodMan420 MethodMan420 is offline
Tell you the truth dropping a 4wd is really a bad idea, it goes against the whole idea of 4wd. Maybe you can set it down a couple inches with the right springs, shock setup, but can't say I would recommend a true drop, belive me i researched it.
IMHO you are just asking for problems with the 4wd setup, they are designed for a certain ride height, dont get me wrong for the right price anything can be done, but are you willing to pay to play?
Before you think about lowering price a new front end rebuild, balljoints, bearings, alignment. I bet after you price the possible rebuild (which is what you will need in 2-3 years) you can deal with the looks. once again just my opinion.
___________
/|____________|\
[|___\==A==/___|]
||||________||||
Old 05-20-2005, 10:05 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
You can do a 4/3 easily by cranking down the torsion bars and then putting drop blocks in the back. After you do that, get it aligned and you will be fine. (Don't forget to cut the bump stops off when you do the blocks)
