Old 05-17-2005, 11:48 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
CLUTCH Engagment Problem!! HELP!!
Ok today i got my car runnin perfect thanks to several of your guys's help. I ran it for about 25 minutes with no problems at all.
But now i have a huge problem. When i push in the clutch the clutch does not disengage. Even when i use my hand and pull up the clutch arm it does nothing. It feels like it is working but maybe not reaching the clutch??? Is there any type of adjusment on these? HELP!
This is what i have by the way:
89 Civic HB
94 Teg engine
90 Teg Tranny
STAGE III Clutch
New throw out bearing
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 05-18-2005, 12:03 AM
Hybrid1990crx's Avatar
Re: CLUTCH Engagment Problem!! HELP!!
you sure you put the spring back on the throw out bearing correctly?
Old 05-18-2005, 12:11 AM
yea, im pretty sure. It feels like it is doing something but its not. Almost like it wont reach the clutch or something thats why i was wondering if there is some kind of adjustment.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-18-2005, 12:17 AM
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-18-2005, 06:15 PM
FabricGATOR FabricGATOR is offline
Send a message via AIM to FabricGATOR
I just re-clutched my civi...... I adjusted the cable length at the trans where I thought I'd leave just a little free play (so the throw doesnt ride the fingers of the pressure plate) It turns out that I actually had to adjust out more free play....
Try this... push pedal all the way. Then while holding a little pressure towards 1st or reverse.... slowly release the pedal and see if you find a sweet spot. A spot that is not all the way to the floor where you have smooth shifting. If so you adjust the cable so there is more slack. It worked for me.......
I re-read your post to be sure I wasnt confused but please clarify....
I read that your clutch does not disengage so that you can select the gear.............. Is this correct? If so then the previous advice is what I found and then adjusted for the fix. I hope this helps...... PS adjustment made at the cable support at the transmission. (black plastic nut on the cable)
Hey! I'm not considered an enthusiast anymore........
2010 Toyota FJ Cruiser Trail Team Edition
2000 Mitsu Montero Sport (Trade In)
1987 944 N/A
1976 Buick Century (SCRAPED)
1979 Yamaha XS1100
I have a parking problem everywhere I go...
2004 Pontiac Gran Prix . . I don't care.
1993 Mustang LX . . . . . I don't care..
1996 Honda Civic CX. . . . . I don't care, well, maybe a just little...
I can't afford to love her anymore!
Old 06-04-2005, 03:38 PM
g-ride-si's Avatar
g-ride-si g-ride-si is offline
im pretty sure i know what ur prob is i just had the same thing happen to me not even a week ago..unfortunately u prob have the wrong clutch disc if it is an 89 that was made after 6/89 u will need a 90 clutch disc there is only a small difference in the center piece of the disc but anymore than 50,000 of an inch is enough to make it not work thats what i had to do let me know if it wotks
