Old 05-17-2005, 10:21 PM
myhd myhd is offline
P0106 OBD2 Error Code
I have this code on my 1996 Grand Caravan (3.8 engine)
This code has this error explanation:
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
What would I do to correct this problem. I have tried to find a solution and have not been successful.
Thanks
Old 05-18-2005, 08:12 AM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Re: P0106 OBD2 Error Code
Chances are the map sensor is bad. There are test that can be done but you would need a scanner and voltage meter to do the tests. The code is more for the baro side of the map. Unless there were some kind of wiring problem I would bet the sensor as being bad.
Old 05-18-2005, 09:13 PM
Thanks for the suggestion.
The light went out today and the code doesn't show up.
I will have it checked or wait until the check engine light comes on again.
