Old 05-17-2005, 08:08 PM
sivic02's Avatar
sivic02 sivic02 is offline
Anyone ever make a battery charger?
I got a problem, i found my old mp3 player but I cant seem to find the charger. I am broke right now so I cant afford to go out and buy one and I cant find a 5v DC charger around the house, anyone have any ideas of what I could do to get this thing charged? I know its ghetto but come on help me out.
Here's to being single, seeing double, and sleeping triple
Old 05-17-2005, 08:38 PM
mysatilac's Avatar
mysatilac mysatilac is offline
If you've got a 4-6 DCV charger you should be OK if they're similar Amperage,
And if you're good you can use batteies wired up to get a temporary charge since its DC, AA are 1.5 DCV so 3 = 4.5V, 4 = 6 V
Try 3 first, yes this is ghetto, if you have a multimeter check the voltage before applying it to the MP3 player,
and try 3 first...
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 05-17-2005, 08:50 PM
sivic02's Avatar
Re: Anyone ever make a battery charger?
The problem with that is I cant find anything that is the right size to plug into the spot on the mp3 player.
Old 05-17-2005, 09:00 PM
mysatilac's Avatar
I've got a bag of spare DC inverters/transformers, I can usually find a plug to fit,
If you can, cut it off a few inches down, wire it up, then when through, solder it back to the converter and wrap individually then both with electrical tape, or open the MP3 player and use where the connections actually run into the machine
If you dont have some experience doing this kinda stuff, I suggest you're going to have to wait for the $ flow to pick back up and then pick up a new power supply
Old 05-17-2005, 09:05 PM
sivic02's Avatar
Ive got a 3.2v charger hooked up to it now, just took a little widening with a tiny screwdriver. Now hopefully the battery will hold a charge, thanks for your help.
Old 05-17-2005, 10:29 PM
mysatilac's Avatar
not a problem, glad you got it taken care of,
Old 05-30-2005, 11:54 AM
Franko914's Avatar
Franko914 Franko914 is offline
Re: Re: Anyone ever make a battery charger?
If you didn't check the polarities of the power plug/receptacle, you're one lucky fella, sivic02. Hope it works, man.
US Supreme Court Upholds the First Gun Law: The Second Amendment
