94 kills when shifted into R or D
Today when pulling up to a red light car started jerking (like when you need to downshift on a clutch-but this car is automatic). When I finally came to a stop, car killed. Now the car will start up fine and run good in Park or Neutral but when shifted into Reverse or Drive it stalls immediately. Any suggestions or ideas? I hope someone can help - it's only the 2nd time I've driven the car!!!
I just found this thread http://www.automotiveforums.com/vbul...light=stalling
which describes exactly what I experienced today. Hopefully thats all it is - not anything major! |
I may have to look into this. My car has stalled a few times in reverse with the wheel fully turned. Ive also been getting a "RPMs too high" engine code but I have no clue WTF that is all about.
Re: 94 kills when shifted into R or D
Certainly sounds like a TCC solenoid or fuel problem. Let us know how long you were driving it, and how fast you were going.
psycho, perhaps a timing chain? |
Today when I experienced this I was approaching an intersection and decreasing from a speed of about 45-50mph and had just started driving 15 minutes prior to that.
search the forums for 'TCC'
!!!!!!!!!!!! your in luck !
hey , your cavalier has a bad, *tries to think of the name* but my 93 cavalier had that problem and they pulled a relay out that helped the fuel management, forgot the name of it, but if you take it to a shop and explain it to them the most they will charge you is like 15 bucks of their time, because its a 2 minute job, when i took mine to the shop for that, he was like oh its this *unplugs some crap* and never had a problem since *2 months afterwards*
Re: Re: 94 kills when shifted into R or D
I am curious, I never heard of reverse stalling out the car with a shot TCC. I guess, given the structure of the drivetrain it makes sense, so I guess no one ever really tried putting a car stalled out from the TCC problem into reverse at a stoplight. Oh yeah, if you go outside now and try to drive it, it should be fine as the Torque Converter should've unlocked itself. Drive it around a bit at highway speeds then come to a stoplight, see if it stalls again. If it does, your TCC is gone. 93njcavalier - I'm betting they pulled the sensor on top of your transmission, didn't they? That controls the lockup of your Torque Converter, which is basically your 4th gear. Without it, you'll notice ultra-crappy gas mileage if you travel on the highways much. You should get it fixed, it only took me about 30 minutes in my home garage. When you're done with that, go back to that garage and tell them not to be such douches and to actually fix shit that needs to be fixed.
1992 Chevrolet Cavalier Z24 *R.I.P.* 3.1L MPFI (3.1 6cylinder Pushrod 12V) 1997 Chevrolet Cavalier Z24 *R.I.P.* 2.4L "Twin Cam" (2.4 4cylinder DOHC 16V) 2003 Honda Accord EX V6 - The new hotness |
Just got my car back and it was indeed the TCC solenoid. The tow was covered under AAA and the garage didn't charge me anything because they didn't replace it, they just unhooked it as I don't do alot of highway driving.
