Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-17-2005, 03:21 PM
zauber zauber is offline
Send a message via AIM to zauber
a moment of silence please
after 3 years of "driving" i blew up my ka sunday night. it took 15 mins of "drifting" two nights ago to break it. i found this sweet church parking lot that actually made some good turns and was large enough to get higher than 20mph, and if i screwed up plenty of room. i say "drifting" because obviously i'm not a drifter. but i did hit some turns at around 50mph and couple turns into turns so i don't suck that bad. anyway, i was in the church parking lot for about 15mins then a car pulled in and my friend was like umm let's bail so i left the lot because i'd rather not get in trouble and on the way home my oil light started flashing. i was like ok not sure why my oil be getting low (since i have to check it regularly due to it eats oil). everything was fine and it started up fine when i left, but continuing my way home every time i came to a stop it would stall. it progressly got worse until the point it started making a horrible knocking sound of metal on metal. i was like shit. since my brother is my tuner/builder i called him and he told me to park my car and he would come check it out. after i stopped that time it wouldn't turn over and made the motor look like it was trying to flip out of the car. he says i bent my rods and froze my back cylinder. i called AAA and had them tow my car to my brother's shop until this weekend when we should be able to start the swap. it should be done this weekend if everything goes smooth. thought i'd share my story, and have a moment a silence for the KA.
in construction: s14 sr20det in my 91' coupe se
Old 05-17-2005, 04:00 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
that sucks...
That sucks... Why was it eating oil so bad? By the sounds of it the last or more then one of the cylinders had bad rings. A couple 100 dollars could have saved this engine I think.
Old 05-17-2005, 04:01 PM
orestes's Avatar
orestes orestes is offline
that sucks. what swap are you doing?
"I got that hustle in my genes like high blood pressure" -E-40
Old 05-17-2005, 04:23 PM
well when i first got it i put 500$ into it to fix the chain and couple inner parts. when we got a look inside the motor then we knew it was going to go, and i was planning on swapping anyway so we decided to just let it go. we've been expecting it actually. i had an s14 sr20 set, but i wanted the clip so my bro sold the s14 motor and we should be going down to pick out my clip here soon. might be tomorrow. though i could do a rb25det or vg30dett they have each of those clips sitting in their shop right now, but i really think i am going s13 blacktop. i am planning on running all stock to get a baseline. then planning on building from there. luckily for me my brother and their shop are kind enough to do everything for me at thier cost if i help of course with the swap, and help them when they need it with computers.
Old 05-17-2005, 06:53 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
Re: a moment of silence please
well at least u were already planning to swap
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 05-17-2005, 08:58 PM
GSR2NR94's Avatar
GSR2NR94 GSR2NR94 is offline
Send a message via AIM to GSR2NR94
NEWS FLASH: Engines require oil for lubrication, so when your oils light comes on and it starts to knock, it is usually a good idea to find a gas station and hydrate it with oil (after making sure it was low). Sorry about your KA though, but who cares, your getting an SR. Ill trade you if you would rather have the KA.
"Drifting is a passion, make love to a corner."
Old 05-17-2005, 09:56 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Teh oil light is not an oil level indicator. It is an indicator that oil pressure has dropped below 10psi. For reference....
You should have 10psi for every 1000rpm. THats Ivan spec.
Nissan spec is more than 10psi at idle
60-70psi at 3000rpm no load.
Damn shitty KA's.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 05-17-2005, 09:59 PM
240SX Guy
I doubt you bent a rod. They're hella strong. You didn't detonate. You prolly just spun a bearing.
-Cory
12.6@122mph
Old 05-17-2005, 10:15 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
yea, i was gonna say, bent a rod? that would be pretty tough.
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 05-18-2005, 01:51 AM
GSR2NR94's Avatar
Yes, but most of the time, if your oil pressure gets low, it is because of low oil level. Is it not?
Old 05-18-2005, 03:02 AM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
the rods on the KA are forged... i would say a piston ring whent out..
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 05-18-2005, 04:14 PM
GSR2NR94's Avatar
Im with nissanfanatic on this one. He probably spun a bearing.
