Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-17-2005, 02:28 PM
GT500916's Avatar
GT500916 GT500916 is offline
Banned
Send a message via AIM to GT500916
Whats the ideal or stock compression on the 240s?
Im going to do a compression test on my 240 tomorrow and what is the stock compression? and what is a good compression on a 129k car?
thanks
Old 05-17-2005, 03:00 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
179 PSI is the norm... and 151 is the minimum. And no more then a 14 PSI diff between cyl.
Old 05-17-2005, 05:13 PM
GT500916's Avatar
Banned
alright tomorrow we will find out... ill change spark plugs and do the compression and we will see where i stand..
Old 05-17-2005, 09:06 PM
GSR2NR94's Avatar
GSR2NR94 GSR2NR94 is offline
Send a message via AIM to GSR2NR94
Re: Whats the ideal or stock compression on the 240s?
My compression wasn't that bad then because it was
1: 170
2:165
3160
4:165
I guess thats not too bad.
"Drifting is a passion, make love to a corner."
Old 05-17-2005, 09:42 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
FActory spec is 179psi
Minimum spec is 151psi
max difference between cylinders should be no more than 14psi.
Since gauge difference is possible, look for difference in the cylinder readings. IF they are teh same or close to, then you're golden. Low cylinders, try adding a tablespoon of oil to. If readings come up, then you have bad rings.
Remember to press the throttle to the floor when cranking. Remember to run the car out of fuel. I like to pull the injector clips and coil wire too.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 05-18-2005, 02:02 AM
GSR2NR94's Avatar
Why do you put it to the floor? Is it just to initiate clear flood mode so that you can crank it and it will not start? Thats what I figured, but I just pulled all of my wires.
Old 05-18-2005, 10:07 AM
240SX Guy
To allow the cylinders to completely fill with air.
-Cory
12.6@122mph
Old 05-18-2005, 02:41 PM
GT500916's Avatar
Banned
cant do compression today as planned, my dad took my car to work cuz the blazer he driver got a little leak going in the tranny ... so tomorrow!!
Old 05-18-2005, 04:16 PM
GSR2NR94's Avatar
which is called clear flood mode.
Old 05-18-2005, 07:52 PM
240SX Guy
Okay. Far more advanced than my talk.
-Cory
12.6@122mph
Old 05-19-2005, 05:03 PM
GT500916's Avatar
Banned
ok just did compression as promised , results are
1- 197psi
2- 189psi
3- 189psi
4- 190psi
the engine was really hot because i just came home from a little drive. Also the oil has been changed on it every 3-5k miles by the first owner and by me, passes smog great, has lots of torque and power... so id say its a brand spanking new car and im happy
i dont even know the stock compression.
Old 05-19-2005, 11:53 PM
monooxide's Avatar
Banned
what!!?!?
The stock numbers are 179 norm and 151 Minimum? What...? 197?
Old 05-20-2005, 01:26 AM
GT500916's Avatar
Banned
Re: what!!?!?
dude im freaken serious!! i did the compression a few times just to make sure, kept getting the same results... like i said i drove the car for like half and hour before the compression... but still...
and i did the soupra compression test just the other day so i know what im doing... for a 130k miles on the 240 hecka good results... unless i have a new engine and the owner didnt say nothing about that?!!
Old 05-20-2005, 01:44 AM
orestes's Avatar
orestes orestes is offline
wtf? did you get a lower profile head gasket maybe?
"I got that hustle in my genes like high blood pressure" -E-40
Old 05-20-2005, 04:06 AM
GT500916's Avatar
Banned
nope! thats why i dont know whats going on. maybe i got some dome pistons in there hahah
my best guess is the engine is new or has been rebuild by the first owner, because he did take care of the car and kept it all stock and changed oils and this and that...
maybe my block shrunk sleaing the rings better after 130k wear...
