Old 05-17-2005, 11:49 AM
DerekM DerekM is offline
Question 2004 antenna replacement ? Need help Please
I was wondering if anyone can tell me what I need to remove to replace
the antenna and the base/mast with the short extension can I get to it through the fenderwell - Mine broke goin through the car wash and it broke it clean off so theres nothing left to screw it into ..
Thanx for any help you can provide..
And hello as I am new here also
Old 05-17-2005, 11:58 AM
BlulytesTB's Avatar
BlulytesTB BlulytesTB is offline
Re: 2004 antenna replacement ? Need help Please
Sorry about that... always take mine off... I do not know... sorry & WELCOME!
2004 Trailblazer LT
Old 05-20-2005, 02:41 PM
parts_guy parts_guy is offline
Antenna Replacement
This is not for the faint of heart. Are you sure you don't want to go to the dealer? Good Luck.
Antenna Cable Replacement
Removal Procedure
1. Open the instrument panel (I/P) compartment to a full down position.
2. Disconnect the radio antenna cable (2) from the radio extension cable.
3. Remove the lower rear portion of the wheelhouse panel. Refer to Wheelhouse Panel Replacement in Body Front End.
4. Reach up behind the wheelhouse panel and remove the antenna cable and grommet assembly from the cowl opening (1).
5. Pass the end of the radio antenna cable assembly through the cowl opening (1).
6. Remove the antenna mast. Refer to Fixed Antenna Mast Replacement .
7. Open the hood.
8. Remove the radio antenna cable assembly retaining screws.
9. Pass the antenna cable and grommet assembly through the fender opening.
10. Remove the radio antenna cable assembly from the vehicle.
Installation Procedure
1. Install the radio antenna cable assembly to the vehicle.
2. Pass the antenna cable and grommet assembly through the fender opening.
3. Install the radio antenna cable assembly retaining screws.
Tighten
Tighten the radio antenna cable assembly screws to 2.8 N·m (25 lb in).
4. Close the hood.
5. Install the antenna mast.
6. Reach up behind the wheelhouse panel and pass the end of the radio antenna cable assembly through the cowl opening (1).
7. Install the antenna cable grommet assembly to the cowl opening.
8. Install the wheelhouse panel. Refer to Wheelhouse Panel Replacement in Body Front End.
9. Install the radio antenna cable (2) to the radio extension cable.
10. Close the I/P compartment.
