Go Back   Automotive Forums Car Chat > Cadillac > SRX
Old 05-17-2005, 09:30 AM
Taurusdave Taurusdave is offline
Question Changing turn signal light bulb
Anyone know the best way to get to the turn signal bulb to replace it??
Old 10-01-2005, 07:23 PM
GMtech07 GMtech07 is offline
Their is no good way. You have to remove the whole assembly from the back of the bumper(yes i am a cadillac tech) it's really a tight spot and a subbie ratchet type wrench is the best way to do it. (yes that tight)
Old 06-23-2010, 07:56 AM
bobco08108 bobco08108 is offline
Smile Re: Changing turn signal light bulb
Owners manual says to go at it from under. I found it much easier to disassemble the grille fascia then remove the headlight assembly and the signal housing.
Old 10-11-2010, 11:34 AM
krivasauto krivasauto is offline
Banned
Too late for the OP, but for the rest of you, try srxturnsignals.shutterfly.com
The Following User Says Thank You to krivasauto For This Useful Post:
Chris Stewart (07-26-2011)
Old 02-06-2011, 10:40 AM
zdld17 zdld17 is offline
In case you are not aware, there is a TSB Campaign bulletin out on this, Supposed to be covered under a warranty or campaign repair.
I recently had my 06 taken care of.
Don Dabbs
Two Dog Town West Tex
Old 02-22-2011, 04:33 PM
samprix samprix is offline
Yes, there was a problem with the light sockets getting too hot, believe. The dealer took care of my '05, but only after I realized that the fix was covered, on the second outage.
Old 12-02-2011, 12:33 PM
ktrsb ktrsb is offline
The new parts and part numbers are at srxturnsignals.shutterfly.com. I made this repair years ago and have not had a problem since.
