5/32 vacum line
i have a 94 jimmy with the 4.3 vortec it idles a little rough and sometimes will die at idle (if in gear) but i was looking under the hood this morning and found the 5/32 vacum line was broke in half that comes off the vacum ball could this be the culprit for the idle and where does the other end hook to thanks
Re: 5/32 vacum line
For the repair, use 5/32 windshield washer tubing and you will be set.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: 5/32 vacum line
i hooked up the vacum ball to the tee looks like someone had blocked it off before still doing the same thing ...ran a fuel pressure test and it runs at 56 pounds with engine off and 60 pounds engine at an idle going to change the fuel filter now hope it helps
Re: 5/32 vacum line
fuel filter was a no go ....has a intermittent misfire has new ac plugs and wires look fairly new only 7mm though could that be it maybe i need to go 8mm? cap and rotor look good and it's not giving me any codes don't know what else to look at any ideas?
Re: Re: 5/32 vacum line
What gap did you set the plugs to?
Re: 5/32 vacum line
gaped the plugs @ .045 the rotor and cap look good ....just cleaned the egr valve and put a new gasket on still the same ole thing
Re: 5/32 vacum line
also put some seafoam in it seems to be burning rich lots of black in the tail pipe
Re: 5/32 vacum line
Did you actually remove the cap and rotor to look at the contacts?
Re: 5/32 vacum line
ok changed the plugs all of them looked good just a little yellow none were black only 1 of them was a bosh and the rest were ac thought for sure that was it but noooo couldn't be that easy. so i changed the wires the miss isn't as bad as it was but it's still there.. i looked at the rotor and cap they didn't look very bad but going to replace them anyways. i took out the tps and cleaned it up it was pretty black anything else you can think of?
Re: 5/32 vacum line
here is something else i noticed . i put the fuel pressure gauge on this morning turned the key on and the pressure went straight up to 60 psi and as soon as the pump kicked off it jumped down to 56 psi. when i started the truck it held a constant 51 psi at an idle and if i gave it the gas it went up to 60 psi is this normal or is the pressure to low
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
