Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-16-2005, 11:38 PM
jkt90eclipse jkt90eclipse is offline
Please Help.. Car Will Not Idle
Hi.. Im new here and have a real big problem and i dont know what to do. I have a 1990 1.8 liter 5 speed Eclipse. My problem is when I crank the car, if Im not pressing the gas, it will cut off on me instantly. When driving, it stalls when I stop, but sometimes I hear a clicking noise and it will idle just as smooth, but after a few seconds I will hear the clicking again and if Im not pressing the gas, it stalls. Can anybody help me??
Old 05-16-2005, 11:42 PM
Re: Please Help.. Car Will Not Idle
Whoops, forgot to mention, black smoke also comes out of the muffler...
Old 05-17-2005, 04:08 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
have you checked normal maintenence things like plugs and wires?
make sure you're getting fuel and spark on all 4 cylinders and that your timing is correct. if i'm not mistaken, the 90 1.8's came with distributors so just get a timing light and set the timing.
95 Talon TSI AWD
97 Eclipse GST
Old 05-17-2005, 11:20 PM
Yeah, ive put new spark plugs, wires, distributor cap, all of that is new.. still wont idle.. any other suggestions?
Old 05-17-2005, 11:36 PM
just because you put all new stuff in doesn't mean it will start. did you actually check to see if you're getting spark at the end of the plugs, or did you just assume it? make sure you're getting spark and fuel pressure. also run a compression test.
95 Talon TSI AWD
97 Eclipse GST
Old 05-25-2005, 01:45 AM
rounder rounder is offline
I had a problem like that and I replaced the plugs and wires and one plug was burnt out. that fixed the problem.
1992 Eagle Talon TSI
FWD
Automatic
