my chirping is still happening
ok, heres the deal. from about 15 miles an hour up to highway speeds. the sound is a chirping (like what birds make). it increases with the speed and no the rpms. it stops whenever i apply the brakes. even slightly. im pretty sure its not bearings and i know its not the suspension or the serp belt. my only thought is becuase it stops when i brake, that it has something to do with the brakes? i dont know brakes systems very well so im unsure of what to look for if this is the problem. as usual any help would be appriciated. any ideas of what else might be wrong would be appriciated aswell. thanks Jess
Yeah, it sounds like the brakes.
Could be that the brake pads are needing to be replaced or un-even wear of either the brake pads and/or rotors. |
Sounds like a warped rotor/brake disc, a common problem, from what I understand.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes 1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials 2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater |
Re: my chirping is still happening
A warped disc/rotor will cause a pumping sensation in the brake pedal when they are applied. This typically does not cause them to make noises. Typically. I am currently driving with warped rotors right now and they do not make any noise. I would say its either the pads or you got some debris lodged in the rotor or somewhere else that rotates.
you could have a sticking caliper, take the wheels off and lube up the rods and rails that the calipers slide on and see if that helps, good way to tell if this is you prob is if one brake pad is worn a lot more than the other
