Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 05-16-2005, 09:46 PM
rubberman rubberman is offline
noise in the rear....
i have a noise inthe rear that happens only when stopping. Actually after the vehicle comes to a complete stop when the rear of the vehicle levels back out. ALmost sounds that something needs lubed up. I will take a look this weekend. squeeky coil or busing or something. the louder the noise when the braking is harder, i guess cause the rear will comeback down level harder.
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 05-17-2005, 12:41 PM
ggcatt ggcatt is offline
Re: noise in the rear....
Sounds like the rear drum brake shoes have become soaked with brake fluid from a leaky cylinder. Pull the wheel(s) and check for fluid leak and gunk in the drum area. If so, replace the cylinder and shoes.
Old 06-20-2005, 08:51 AM
the sound is only when stopping in a forward position. Never makes the sound when stopping in reverse. I pushed up and down on the rear the vehicle and it doesnt make the noise. only applying the brakes and the vehicle levels out.
Old 06-22-2005, 06:50 AM
fishhead65 fishhead65 is offline
I had the same issue. It is the rear brakes. Should be cleaned and/or replace shoes.
Old 06-22-2005, 10:00 AM
1999montana's Avatar
1999montana 1999montana is offline
Re: Re: noise in the rear....
Ours does it too.
It sounds to me like the bushings in the rear axle control arm links might be the cause. Could try squirting some WD-40 or silicone lubricant in the bushings to see if it softens or eliminates the sound. Can't hurt.
I haven't tried WD-40 yet, but may this weekend.
If you have load-leveling rear suspension check that the link from the controller to the axle is free and not binding too.
Old 06-22-2005, 12:12 PM
got the rear leveling system on our van. I have never replaced the shoes on a drum brake system (have many times on a disc brake system) so i'll have to check them out. is it harder on a drum system?
I have a year and half left on my loan then this baby is history. I just hope it will hold out till i can trade it in then.
