Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 05-16-2005, 09:19 PM
whiskers whiskers is offline
first oil change
i have a 2004 prerunner it has 2,000 miles on it. i rarely drive the truck. i have had it since june 2004. i know the manual recommends oil changes every 5,000 miles. since it has been about one year and knowing that i wont be putting 5,000 miles on it for awhile, should i change the oil now? When have you guys that bought new trucks changed your oil for the first time?
Old 05-17-2005, 03:20 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: first oil change
Time is just as critical of a factor for oil life as is mileage, if not more so. I would change the oil every 6 months at least. The first oil change should be a bit sooner than scheduled to get rid of the high wear metals caused by break-in wear. The larger exposed surface uses up the metal-coating additives faster than normal use later in the engine's life.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
