Old 05-16-2005, 09:04 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Fuel Lines, Brake Lines, Braided Lines, Oh My
ok. i've picked up some craft wire from wal mart. hoping it works for some detail. here is my question what size/guage detail wire is used for what? Race and Street applications
Braided line?
Hard Line?
Fuel lines
brake lines
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 05-16-2005, 10:22 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
Hey, for fuel lines, fire lines, and brake lines etc.. i use this stuff called floral wire.
i pick it up at the dollar store. you get a ton of it!
for braided line, i recommend using mini blind cord. its more realistic than even DM braided line.
Old 05-16-2005, 10:54 PM
white97ex's Avatar
Re: Fuel Lines, Brake Lines, Braided Lines, Oh My
sweet.any idea what guage that floral wire is? i've got some i got at wal mart some time ago....i knew i've been needing to trim these blinds for a reason lol
Old 05-17-2005, 07:47 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Detail master makes some stuff. Its about $3 a for some 5' lengths. I'm going to be getting that for my Camaro.
-Mike
Old 05-17-2005, 10:29 AM
white97ex's Avatar
yeah. I've seen the DM stuff. i was just wondering what guage all of that stuff translates into. you can get 30 yard spools of 18 20 and 24 guage craft wire at wal mart
Old 05-17-2005, 01:25 PM
mn80228's Avatar
mn80228 mn80228 is offline
According to my numbers....
18ga wire = .0403" = .96" at 1/24
20ga wire = .0320" = .77" at 1/24
24ga wire = .0201" = .48" at 1/24
So it looks like you have 1", 3/4", and 1/2" diameter respectively.
Not sure what diameters most fuellines, brake lines, and all that are, but hopefully this will help out.
-matt
Matts4LittleWheels.blogspot.com
Old 05-17-2005, 01:45 PM
klutz_100's Avatar
Matt,
Wanna give me those in centimeters and millimeters?
What the heck's a "gauge" anyway? I'm a
stevenski
PS telephones have been my best sorce of plugw ires and brakline brass wire so far plus my old guitar strings are usefull too
Old 05-17-2005, 01:52 PM
white97ex's Avatar
matt's post plus this link should prove quite useful around here.....
http://detailmaster.com/wire.htm
mn80228's Avatar
Stevenski....
Good point.
18ga wire = 1.024mm = 24.5mm @ 1/24 scale
20ga wire = 0.813mm = 19.5mm @ 1/24 scale
24ga wire = 0.510mm = 12.25mm @ 1/24 scale
Again, hope that helps.
As far as a gauge, it is a measure of the thickness in some way or other.
Not sure exactly where it comes from.
But I just looked up the sizes for the gauges, and then scaled them.
-matt
Old 05-17-2005, 02:12 PM
klutz_100's Avatar
-matt
OK Matt - you scratch my gauge, i'll scratch yours.....
"American Wire Gauge (AWG) is a U.S. standard set of non-ferrous wire conductor sizes. The "gauge" means the diameter. Non-ferrous includes copper and also aluminum and other materials, but is most frequently applied to copper household electrical wiring and telephone wiring. Typical household wiring is AWG number 12 or 14. Telephone wire is usually 22, 24, or 26. The higher the gauge number, the smaller the diameter and the thinner the wire. Since thicker wire carries more current because it has less electrical resistance over a given length, thicker wire is better for longer distances. For this reason, where extended distance is critical, a company installing a network might prefer telephone wire with the lower-gauge, thicker wire of AWG 24 to AWG 26.
AWG is sometimes known as Brown and Sharpe (B&S) Wire Gauge. "
also webster's:
" Wire gauge or gage.
(a) A gauge for measuring the diameter of wire, thickness
of sheet metal, etc., often consisting of a metal
plate with a series of notches of various widths in
its edge.
(b) A standard series of sizes arbitrarily indicated, as
by numbers, to which the diameter of wire or the
thickness of sheet metal in usually made, and which is
used in describing the size or thickness. There are
many different standards for wire gauges, as in
different countries, or for different kinds of metal,
the Birmingham wire gauges and the American wire gauge
being often used and designated by the abbreviations
B. W. G. and A. W. G. respectively."
Thanks for giving me the decimal numbers - I am embarassed to be so lazy Sooooooooo publicly
best regards
stevenski
