Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-16-2005, 08:16 PM
themindbender themindbender is offline
A/C problems
Hello two days ago I noticed that the a/c was A. not blowing very hard, and B. not very cold. I am in Tucson and the temp is hovering around 100 and will only climb. Now today, sure thing, very little air pressure on the driver side but good on the passenger side. The temp is still warm. Also, now that I think about it, about a week ago, it took about 20 min. for the a/c to get "comfortable" in the car and that was at freeway speeds (80mph). Any help would be great. I have a pressure gauge but don't know where to test it at. My old '68 Impala is easy, but this is mind-boggling to me. The only idea I have is that there are two spots behind the battery, towards the firewall. One is straight on top and the other is lower and bends towards the air cleaner. Can I check the pressure at either spot?
Old 05-26-2005, 11:35 AM
DJ_4_life03 DJ_4_life03 is offline
Send a message via AIM to DJ_4_life03
Check the pressure at the upper one. And if you do notice that you have to refill your A/C make sure that you release the old A/C out of the lower on and refill it into the upper one. Your car has to be on and your A/C on MAX when refilling. Have anymore questions - post a reply or E-mail me [email protected]
Old 06-02-2005, 11:02 PM
monte85 monte85 is offline
Lightbulb ac problems
HI IT SEEMS THAT YOU MIGHT HAVE AN AC COMPRESSOR PROBLEM! YOU MIGHT BE ABLE TO GET IT TO WORK. YOUR ORFICE TUBE MIGHT BE CLOGGED AND NOT COOLING AT IDLE ,BUT WHEN YOU RAISE THE RPMS DOES IT COOL? IF SO YOU HAVE CHANGE THE ORFICE AND VACCUM THE SYSTEM THEM ADD ABOUT 2 CANS OF R=134. IF HAVE ANY QUESTIONS EMAIL ME @ [email protected]
