Old 05-16-2005, 08:46 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
HELP!!! B18 wont run over 2K RPMS!!!
I finally got my engine running but now i have a problem. The engine wont rev past 2000 rpm it just spudders and almost dies. Also the car wont start on its own i have to spray starting fluid in the intake and then it runs fine on its own.
What could the problem be??
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 05-16-2005, 08:51 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: HELP!!! B18 wont run over 2K RPMS!!!
Im not sure about this particular swap, but I recall some others having this problem, and 2 of the sensors and their connectors were backwards... Id recheck that and your wiring...
Old 05-16-2005, 10:17 PM
Hybrid1990crx's Avatar
throwing any codes? sounds like it could be crank angle.
Old 05-16-2005, 11:06 PM
how do i check for coeds?
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-16-2005, 11:21 PM
Depends, did u keep it preOBD or go ODB1? (which ECU did u use?) If u kept it preOBD then u just look at the ECU (should be an LED on the front of it when u move the carpet youll see it) and count the links, look them up on the internet, if its OBD1 then the check engine light should be on (if u hooked it up), if it is, ground the check engine light jumper (u should have wired a switch or something if u wired up OBD1) and count the blinks on the check engine light...
Old 05-16-2005, 11:47 PM
Ok i did the test and it blinked 7 times.
(I CONVERTED TO OBD-1)
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-16-2005, 11:48 PM
Code 7 (7 flashes) Throttle angle
Old 05-16-2005, 11:50 PM
i took the TPS sensor out of a d15 engine because the one on the B18 was broken. Can you not switch them?
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-17-2005, 12:12 AM
SORRY MY BAD, It was 16, 1 long one and 6 little ones. That would be the Fuel Injector System. Does that mean that the injectors are bad? I checked all my wiring and its all correct.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-17-2005, 12:21 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: Re: HELP!!! B18 wont run over 2K RPMS!!!
are you absolutely sure...? did you do the MPFI swap.
Old 05-17-2005, 12:24 AM
yea, iv checked it 3 or 4 times. Since it was OBD1 all you had to do is hook the injecters straight up to the ECU and up to the ignition switch. I used color coded wires so it was pretty straight forward. It runs but it doggs down at about 2K. This happend to my 240sx once and it was 2 of the injectors. So tonight i will go switch out the injecters and see if that fixes the problem.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-17-2005, 09:48 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
did you get the tps from a 88-91 dx 1.5 d15b2 engine?
if you used the tps from that engine, then you have to switch the outer two wires on the tps...the 1.5 dx one and the ls one are wired differently.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 05-17-2005, 12:47 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
i thought the TPS from the dual point engines turned the opposite direction.
i know that when you do the multipoint conversion, you need to switch two wires on the TPS plug, but if the dual point sensor operates differently, wouldnt that mean either its useless for multipoint? or if it can be used, wouldnt you have to leave the two wires alone?
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-23-2005, 04:11 PM
bambam89lx's Avatar
AF - Advisor
no...if you mount it backwards, it works...instead of pointing down to the left, it would point up and to the right
