Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-16-2005, 06:56 PM
fred495us1 fred495us1 is offline
Unhappy electrical problem
I have a 92 crown vic lx. This problem started about 7 months ago. The car starts fine and runs great. This problem only happens about once a month. almost everything electrical on the inside turns off and will not work. The radio, clock, power windows, mirrors, and windshield wipers will not work. it also will not pump washer fluid. The power seats work but run a little slow. The signal lights and hazard lights run really slow( about one blink every 2-3 seconds). headlights work but are dim.
I have checked the fuses and i found out that one of them was burned out. After testing all of the switches i found out that it was the headlight switch. I have not replaced it yet because it still works. It only burns the fuse if i turn the delay off.
With that said, the second time i had this problem i checked the fuses again and they were all good. the fuse for the headlight switch had not burned.
the voltage meter normally reads at about the R. When i am having this problem it reads a little below the O. If i drive the car for about 15 minutes everything turns back on. I took my car to a local mechanic that does all of the major work on my car. He tested the alternator and battery and it was charging.
Old 05-17-2005, 02:07 AM
ModMech's Avatar
ModMech ModMech is offline
Re: electrical problem
You have a bad power or ground cable to the body/chassis most likely. They can be very tricky to find as they might LOOK good but not conduct well.
I suggest you start at the battery and follow the main cables to whereever, and make sure all the connections are clean and tight.
Old 05-30-2005, 06:08 PM
wasabiboys's Avatar
wasabiboys wasabiboys is offline
Send a message via AIM to wasabiboys
I would check maybe the battery and the alternator. Also all the relays and fuses, check over!
1992 Crown Victoria 185,000 Miles with Flowmaster 40s , K+N,
1992 Volvo 244 2.3L 107,000 Miles Borla, Ram Air, K+N, PIAA Fog Lights
