98 Buick Regal GS won't start
I need help, Please!
I have a 98 Buick Regal GS. When I was stopped, waiting for a light to change, it stalled. The starter wouldn’t turn, but the ignition was turning on. After a little while (15 minutes), it started again. I was able to drive it about another 4 blocks, and it died again. Same thing with no starter turning, but the ignition working. Now the power windows don’t operate along with anything else inside the car, but the instrument panel lights up when you turn the key in the “On” position. I’m dazed and definitely confused, and don’t know where to look, now. The battery is still fully charged. I think it may be an electrical short or a bad relay, but have no idea where to look. Thanks All,
Big Dan58 Panic, Chaos and Confusion... My work here is done! |
Re: 98 Buick Regal GS won't start
Check the wiring at the battery and where the negative wire connects to the block. It appears you have a bad connection especially since everything goes dead. It could also be in the starter solenoid as the majority of the electrical power for the vehicle goes through the solenoid. You could have a bad connection there.
Re: Re: 98 Buick Regal GS won't start
Not necessarily, the engine requires a good ground to start due to the amount of power that is needed to turn the starter and engine. There are also other grounds to the other areas of the car and even a small amount of ground will allow the lights to come on.
Check the wiring at the starter solenoid. Sometimes they fray and don't allow good contact. This is not a ground but a hot wire but can cause a lot of trouble. The other possibility is that the battery is bad internally and not putting out enough voltage to turn the car over. I just had a friend that had a new battery and would not start the car. The battery had faulted internally and even though the lights worked the vehicle would not start.
That is always possible. Is the security light on? If so you may need to have the entire system reset. These things are a good idea but they can be a PITA. If you have a different original key try it as that may cure the problem or at least make it start. Unfortunately I have limited knowledge of this system since most of the books don't even mention them and they can cause huge problems.
I have the same problem with my 98 regal it sounds like. Did you ever find anything out. I have been going crazy trying to figure this out.
Welcome to AF. This thread is 2 years old, and dead at this point, start a new thread, thanks.
