Old 05-16-2005, 02:31 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Oil Pressure
Im still having problems with my oil pressure gauge. I know its the wiring (I think). What I have is the gauge all hooked up: + and - are going to the cigarette lighter. The sender is installed and the wire going from there goes straight to the gauge. Now, when I turn the car on, the gauge goes to 0psi. When I turn the car off, it still sits at 0psi until the wire from the sender gets disconneted. (It's a split wire, so that's how I know). The it goes down to the full off position. I tried taking the split wire from the sender and grounding it to the chasis, but then it shoots past 100psi, and never comes back down. It also goes up there when the engine is off, but electrical is on. Any ideas? Do I need to ground the sender to the block or something?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-16-2005, 05:35 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Oil Pressure
you wired the light to the cig, ran a ground from the gauge to the frame/body, and wired the power wire from the gauge to the ignition under your stearing wheel??
DSM geek
Old 05-17-2005, 08:59 AM
david-b's Avatar
Dave is THAT guy
Re: Oil Pressure
The light and power to gauge are kinda in the same deal. There's alittle black box unit that allows the light to turn on. That's wired to the cig light, which also supplies the gauge power. I have the same setup with all my gauges.
Right now there is no ground coming from th sender unit. It just goes straight to the gauge sender terminal.
75 Monte Carlo
Old 05-18-2005, 07:56 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Oil Pressure
In some cases the sender doesnt get grounded well. With my sender remote mounted, it was easy to ground (and even more important to do it). I just put a hose clamp around the metal body with a wire under it, then ran that wire to a ground bolt. Not sure if this will fix your problem, but its worth doing anyway.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-18-2005, 04:36 PM
david-b's Avatar
Dave is THAT guy
Re: Oil Pressure
It turns out that I hooked it up tot the wrong place. The post that titled "Does anyone have a Haynes manual" showed me that I hooked it up to the knock sensor, not the OP. Im working on that now. Thanks tho.
75 Monte Carlo
