Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-16-2005, 01:05 PM
c5tech c5tech is offline
93 transmission prob no 1st gear no od help please
I'm having problems with a 93 jeep gc. The trans will not downshift and will not go into overdrive. You can manually downshift, but I only get 2nd and 3rd. When first started it will go in 1st but not again after coming to a stop. It tries to take off in third at lights and will only go down to second manually. the od light will not come on or off or engage. I checked for codes and only flashed a 55 for end of codes. I checked fuses all good. i'm thinking about bypassing the tcm relay to see if it's bad. Could it be an input out put sensor? od /tcc solenoid Any help is appreciated thanks
Old 05-16-2005, 03:22 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Sounds like bad shift solonoids. I'd go to a tranny shop and have it properly diagnosed
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 06-06-2005, 11:17 AM
rpady rpady is offline
Re: 93 transmission prob no 1st gear no od help please
c5tech,
when you come to a stop, shift thru the ranges up to park and back to 1st gear and see if it will start out in first. If not, make sure your trans oil is at proper level. I have the very same problem and have not found an answer yet. Mine will work as it should on occasion, just depends at engine start what it wants to do. Let me know if you find a fix and i will do the same. Thanks, Rob
Old 06-07-2005, 03:56 PM
Re: Re: 93 transmission prob no 1st gear no od help please
Fixed mine today with a TCM.
