Old 04-12-2002, 12:51 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
rebuilding b18b
i am planning to rebuild a b18b what all am i going to need?
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 04-12-2002, 01:04 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: rebuilding b18b
Well it depends on the set up you want. All motor? Forced Induction? Or regular specs just to replace the old with new pistons at stock?
Old 04-12-2002, 01:52 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
money, good machine shop, money, know-how, money, idea what you want to do w/ motor, did i meniton money??
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 04-12-2002, 01:55 AM
spy54's Avatar
i already got the talk from moppie "if you have to ask you shouldn't do it" en just slap a turbo on it and run it till it blows i wish um mellow i was think N/A b/c i can't afford a turbo
AF Teen Crew
Old 04-12-2002, 08:35 AM
mellowboy's Avatar
Well hey thats not a bad idea man. I'm goin all motor. Get higher compression pistons (11:1) so that way u don't have to use racing gas. Port and polish head, valve angle job, skunk 2's camshaft and cam gears, and i would get a skunk 2 valve train and the manifold. Reprogram your ecu. Well thats just some just to give you an idea.
Heres my set up that i'm plannin to do:
Skunk 2 camshaft (possibly a stage 2)
Skunk 2 cam gears
ITR or Skunk 2 valvetrain
reprogram my ecu (mugen chipped )
ITR or Edelbrock manifold
Jdm 4-1 headers
CTR pistons
Port and Polish head / valve job
ITR or CTR lsd
act clutch stage 2
7.9 lb flywheel or 11lb.
All that above should cost around like 2500 - 4100.Anyways that set up i have above should be a good mid to high 12's or low 13's with upgraded clutch and flywheel and lsd.
Old 04-13-2002, 02:32 AM
pvang31019 pvang31019 is offline
a machine shop for the machining, ring compressor, ring filer, torque wrench, sandpaper(put a nice crosshatch on the walls and debur thsoe valve reliefs), feeler gauge set, platigauge strips, a lot of assembly lube, etc....pretty much more than the usual I/H/E guy can handle
94 Ranger Tranny rebuild freakyfire05 Ranger | Courier 0 09-11-2010 03:11 PM
2000 z71, 5.3 budget rebuild, any tips nthnkng33 General Discussion 2 07-20-2010 09:06 PM
4R55E tranny rebuild problem mrstubb Explorer | Explorer Sport Trac 1 05-30-2010 10:27 PM
1994 f150 5.0 rebuild spoovey F Series 4 03-19-2010 06:30 PM
Engine Rebuild abc234 Aveo 1 05-17-2009 06:38 PM
