Old 05-16-2005, 09:59 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Advance timing with this mod????
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
This is most definitely a scam but what harm can be done by doing this and how does it possibly work? Does it put the computer into a loop mode or something? This is very confusing!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 05-16-2005, 10:04 AM
Jergin01's Avatar
Jergin01 Jergin01 is offline
this mod definatley looks like it will screw up your ecu. dont even try it
2000 S-10 Blazer LT 4.3L EFI 4DR 4WD
Alpine CDA-9835 Headunit w/ iPod
Custom Wheels w/ Toyo 255/40/20
Custom Exhaust - 3" Chrome Outlet
All Clear Lights w/ L.E.D Bulbs
Silver Interior w/ Brushed Aluminum Trim Pieces
Check out my Blazer on CarDomain.com
http://www.cardomain.com/ride/856449
Old 05-16-2005, 10:20 AM
Oh I was not going to do it, just thought I would mention it and see what you guys think, it seems so wrong.
K&N Air Filter
Old 05-16-2005, 12:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Advance timing with this mod????
It is an Intake Air Temperature Sensor mod.
Makes the ECM think the air is colder coming into the engine so it will dump more fuel in.
The thing is, the computer will see that it is out of whack and correct it.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-16-2005, 01:51 PM
Re: Re: Advance timing with this mod????
So reading through some of these posts I have noticed that the computer will correct a lot of different things on it's own when you "mod" it. There is probably no answer to this question but about how long would it take? Say I did this mod? Got more horses? How long would it last?
K&N Air Filter
Old 05-17-2005, 12:14 AM
BlazerLT's Avatar
AF -Advisor
500 miles or so
Old 05-17-2005, 01:17 AM
crazy4nitro's Avatar
crazy4nitro crazy4nitro is offline
even if it did fool the computer and dump more fuel in ,that would made the mixture FAT or rich. Rich mixtures do not yeald as much power as leaner ones.(with in reason). so in theory I call it a SCAM..
Old 05-17-2005, 01:20 AM
BlazerLT's Avatar
AF -Advisor
This is true, but the oxygen sensors will lean out of rich mixture by reducing injector pulse width over time.
You will get a small increase in power as the computer advances the timing to coincide with the increase of fuel, but it will eventually relearn and adjust it back to normal.
Old 05-17-2005, 09:00 AM
tubjub's Avatar
tubjub tubjub is offline
Send a message via ICQ to tubjub Send a message via AIM to tubjub Send a message via MSN to tubjub Send a message via Yahoo to tubjub
alright, maybe i don't know what i'm talking about here, but i'll have to disagree with you there.
if richer mixtures don't yield as much power, then why is it your car runs slightly better when its cold versus when its fully warmed up ? (mine does at least) it seems to me (to a point) that the more gas you can get into your cylinders, the better.
lean mixtures can be deadly, especially with forced induction. ... they burn holes in pistons, produce knock and ping, and are poor for power and driveabliity.
again this is all my opinions, and i know i'm sticking my neck out here and i'll probably be corrected... but whatever... someone correct this
This is your life and its ending one minute at a time...
Old 05-17-2005, 03:23 PM
biv343 biv343 is offline
Re: Re: Re: Advance timing with this mod????
More fuel is better, to a point. If you can flow enough air in and out of the engine to compensate for the additional fuel flow, then you (in theory) will get more power up to a point. Obviously, there is much less control nowadays with computers.
Someone who plugged this 15 cent Radio Shack resistor into their air temp sensor on a bone stock vehicle might notice a difference for a short while, until the ECM "learns" what's happened, as BlazerLT mentioned in a previous reply.
But, more fuel with the same air flow will make for a rich mixture which wastes fuel, increases emissions, etc.
And you are 100% correct about the lean mixture - I'd take an engine that runs a little rich over an engine that runs too lean anyday. Spark plugs are cheaper than pistons. Of course, an engine that runs with a air to fuel mixture of 14.7:1 will always run the best....
Old 05-17-2005, 04:58 PM
BlazerLT's Avatar
AF -Advisor
You have to remember timing.
The computer will advance the timing as well.
Old 05-18-2005, 10:03 AM
tubjub's Avatar
yeah ... timing, i forgot about that. BECAUSE its gonna be way advanced until it warms up ...DUH
