Old 05-16-2005, 09:52 AM
mitchdakid mitchdakid is offline
Unhappy A.C. problems
Major problems with the A.C. someone please help. I am moving to Arizona in two weeks and I have got to get this figured out. My 96 Blazer, will not blow cold air and has now started to make a horrible noise. When I checked it out under the hood it sounded like the rubbing-sqeaking noise is coming from the a.c compressor. Does this sound like my a.c. compressor seized up or something else. I also added frion last year when I bought it and it was cold so i will check to make sure I don't have a vacuam leak, but I don't think that it will cause that horrible noise, any help would be grateful, thanks.
1967 mustang coupe
new candy apple red paint with charcle striping, 351 windsor rebuilt 100 miles ago, 463 butt gears, B&M QUICK SHIFT, c-4 Transmission, shaved door handles, custom interior - not finished yet, 68 gt wheels-powder coated, slicks for the track, mustang 2 suspension.
1996 Blazer LS 2 door 4wd
aftermarket muffler-Flowmaster 40, cold air intake coming, blazer extreme body kit on it's way also, front has been lowered with tensioners, and rear with a block.
Old 05-16-2005, 10:01 AM
Jergin01's Avatar
Jergin01 Jergin01 is offline
start the car and turn on the air conditioner, now check to see if the belt is actually spinning the compressor, if it isn't then your air seized on you.
2000 S-10 Blazer LT 4.3L EFI 4DR 4WD
Alpine CDA-9835 Headunit w/ iPod
Custom Wheels w/ Toyo 255/40/20
Custom Exhaust - 3" Chrome Outlet
All Clear Lights w/ L.E.D Bulbs
Silver Interior w/ Brushed Aluminum Trim Pieces
Check out my Blazer on CarDomain.com
http://www.cardomain.com/ride/856449
Old 05-16-2005, 12:07 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: A.C. problems
Also, you have to add oil with the refrigerant.
If not, your compressor will seize up.
The AC system fluid is comprised of refrigerant and oil.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-16-2005, 01:04 PM
Re: Re: A.C. problems
I thought that the oil and the refrigerent where the same, or is that what you are trying to say is that I just need to add some, so that the compressor will be oiled.
1967 mustang coupe
Old 05-16-2005, 01:18 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: A.C. problems
No, they are not the same.
You have to use a mixture of the two.
The compressor is lubricated by the oil which is carried along by the refrigerant.
If you compressor is making noise, the oil may help, but it is probably to far gone by now.
3-4oz should help.
Old 05-17-2005, 01:01 PM
actionpaintball actionpaintball is offline
Re: Re: Re: Re: A.C. problems
You need to add R134A and not Frion-and one can of ester oil
Old 05-17-2005, 01:16 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Re: A.C. problems
No, you add the appropriate mixture of oil for the R134A used.
