Old 05-16-2005, 07:07 AM
rostrihon rostrihon is offline
1994 lumina apv shorted
my temp sending unit wires were exposed from the exhaust manifold heat and shorted together. now no spark to the coil. checked all the fuses i know of can anyone point me in the right direction.
Old 05-16-2005, 07:59 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 1994 lumina apv shorted
I'd wonder. If it was the sensor that the computer uses, it would have shorted the ECM to ground. They don't like that.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 05-16-2005, 08:12 AM
unfortunately yes
the exposed wires from the temp sensor sparked unfortunately the key was on when i found the problem they shorted together now no fire to the coil. sounds like the computer is a good place to start. thanks for your help
Old 05-16-2005, 10:13 AM
Re: unfortunately yes
Lotsa parts stores can "bench test" the ECM now, so you're not gambling.
...empty gun rack.
Old 05-17-2005, 09:47 AM
follow up
ok i may be playing with fire here but the positive wire that i saw short out to the ground wire i jumped a new positive to the end of this wire. my thinking was if there is a fusible link or something i couldnt see without gutting the wire harness i would supply power back through the line to see if everything powers back up. well it worked probably not the right answer but might help someone off the side of the road.
Old 05-17-2005, 12:29 PM
Interesting solution. Cool! May be a link, like you said.
...empty gun rack.
Old 05-21-2005, 12:07 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the fuseable links are located at the starter, where the main battery cable bolts to it. Also check the underhood relay/fuse center to see if one of the Maxi-fuses are burnt.
Old 06-03-2005, 09:10 AM
joy's van joy's van is offline
Help I bought this van with 134, on it the battery would,nt keep a charge. so i replaced the altenator It ran really good for about 3weeks now the battery is dead again and i can hear a whinning noise coming from the power doors do you think i have a short can this be disabled
